Th echarge light is in series with the field wire on altenator, if the field winding is drwaing power rather than making its own current flows to the altenator via the light and light glows.
Sounds like the installer has picked up thew power source from this wire on the ignition switch side of charge light, the timer is then drawing power backwards through the circuit and lighting up the globe.
Wiring diagram should be pretty plain where it needs to run from.
Would have thought that it had to pick power from somewhere that has power all the time regardless of switch position.
regards
jon
....it may have sounded silly on the surface, but there are more functions to a timer then the timer function i.e
I figured as much, but it did sound a bit strange on the surface so I felt the need to clarify anyhow
