Results 1 to 5 of 5
Thread: Help with FE cams removal
    Altia ER34 GTT Domestic Engineer JetspeedCamry's Avatar
    Default Help with FE cams removal
    Taking the cams out of the V6, ive encountered a problem.
    In order to remove them without damage, you must rotate them until the marks on the main scissor gears line up, and then put a service bolt through the main and sub gears to stop there torsional force when removing them.
    Ive got the rear bank cams out without a problem. However, when doing the front bank, after i lined up the marks on the main gears, the service bolt hole doesn't line up exactly. It's about 1/2 a hole width out, so i can see through, but a bolt wouldn't engage. The teeth on the gears themselves is perfectly aligned, so i'm wondering what exactly to do?
    Any ideas?
    Thanks.
    Kind Regards,
    Kurt.
    1998 ER34 ニッサン スカイラインGT- T
    Junior Member Backyard Mechanic jonra23's Avatar
    Jun 2006
    Default Re: Help with FE cams removal
    Sounds like the sub gear and main gear are 1 tooth out of sync, have the cams been out before?
    No great ideas on how to fix it until the two cam scissor gears are not meshed.
    what? Automotive Encyclopaedia EVOSTi's Avatar
    maybe just remove the cam and align it after you have it out. like mentioned it was probably missaligned by someone previously.
    south australia
    i don't understand because i have never played with this sort of thing, but can't you just put a thin rod through the hole instead?
    Quote Originally Posted by jonra23
    Sounds like the sub gear and main gear are 1 tooth out of sync, have the cams been out before? No great ideas on how to fix it until the two cam scissor gears are not meshed.
    Yeah this is what i thought. I havn't taken the cams out of this motor before my self, as it's one i sourced from a wrecker.
    Quote Originally Posted by EVOSTi
    I didn't want to remove it without bracing the gears with a bolt or similar, because the manual states that it may cause head damage when the tension of the gears are loose.
    Quote Originally Posted by barned01
    Well what you suggested was what i was going to do..thankyou for the clafification
    I guess theres no way to realign the sub and main gear without having the cam out...so a pin it going to be the only option.
    Thanks to all
    Kind Regards,
    Kurt.
  1. [warning] TRD 272degree cams for 4age
    By progkamol in forum Tech and Conversions
    Last Post: 19-07-2006, 09:48 AM
  2. 272deg Cams, Bigport GE, Stock Comp...Big Improvement!
    By craigy in forum Tech and Conversions
    Last Post: 07-04-2006, 03:00 PM
  3. 2jz-ge cams
    Last Post: 16-03-2006, 03:56 PM
  4. 2jzgte cams in 1jzgte do they fit without mod
    By 1JZ.747 in forum Tech and Conversions
    Last Post: 12-01-2006, 08:54 AM
