Results 1 to 8 of 8
Thread: RA-23 diff gears
    Graphic Designer Grease Monkey Petes77celica's Avatar
    Default RA-23 diff gears
    Hey guys im just about to cahnge diffs in the celica aswell as the ratios i was just wondering what diff gears they run standard just so i know if my speedo will be out. I did have a search but couldnt seem to find anything. Any help would be great.
    Thanks Guys
    Default Re: RA-23 diff gears
    Best to look on the plate in the engine bay for the diff code.. Mine was 4.1 or there abouts.
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    More than probably a T292 diff... in which case it is 4.1:1 ratio. Ive not heard of other ratios in RA23s. Unless craptomatic had a different ratio??
    Cheers thanks for that guys much appreciated!
    Pete
    Hung like planet Pluto... Backyard Mechanic Rcubed's Avatar
    QLD!
    Quote Originally Posted by Petes77celica
    Pete
    http://ourworld.compuserve.com/homep...od.htm#cel23pr
    http://ourworld.compuserve.com/homep...tepho/diff.htm
    4.1 [T292] in manual but auto had option of 4.3 [T282].
    T18 had 3.909 [T312] or 3.727 [T302]
    look on build plate for these numbers
    1. There's no point arguing with an idiot. They'll just drag you down to their level and beat you with experience
    2. Don't argue with an idiot; people watching may not be able to tell the difference
    I direct your attention to the Toyota Axle Database:
    http://www.norbie.net/ToyotaAxle/
    My RA23 was auto and came with a T292 (4.1:1). I believe the T312 (3.9:1) was optional but I've not come across one.
    User Conversion King
    NWA
    T312 was in the RA60 celica
    i also found a RT132 build plate which indicates T312
    hello
    Edit - My bad
  1. changing the gear ratio's in hilux diff.
    Last Post: 14-10-2006, 01:41 PM
  2. jza80 diff mounts into the diff cradle ???
    Last Post: 08-05-2006, 01:35 AM
  3. Diff Question
    By mlaser in forum Tech and Conversions
    Last Post: 17-04-2006, 09:13 PM
