1st year Apprentice
Steering arm and ball joint problem
Hows it going guys,
I have a problem tightening the nut for the the steering arm and ball joint on the outer tie rod. What is the tool called to tighten that nut and where can i get that tool.
Thanks in advance for the help guys.
Virgilio
Junior Member
Grease Monkey
Re: Steering arm and ball join problem
The same thing happened to me and I just figured the thing was buggered and replaced it, then the new ones didnt spin at all, so I would say thats yours has had it too.
Bit confused which bit you are talking about.
If you are talking about the tie rod end into steering arm on hub a bit of downward pressure on the top of the tie rod end with tyre lever or like usualy has enough pressure to stop the taper turning in the steering arm.
If tie rod end onto tie rodmake sure you aren't trying to join a right hand thread and left hand thread item.
1st year Apprentice
thanks guys the thread on both the nut and ball joint is fine just tough to rotate. stopping the joint from rotating is the tricky bit but will try it again tomorrow when theres daylight.
Thanks again
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
