Results 16 to 23 of 23
Thread: Injured turbo blades- symptoms?
    Not in the diner Alf! Conversion King RyleyMA61's Avatar
    Default Re: Injured turbo blades- symptoms?
    well, a bigger turbo would be lovely.... but then i'd want to re-do my headgasket to another metal one... and it'd be another whole round of spending on shit like clutches!
    i haven't even experienced above 6psi yet
    so 12psi and around 200rwkw is going to make every set of pants i own brown*, let alone with teh massiv turboz0r
    *hopefully
    Bigger volume pipes and intercooler will also take more time to fill up now at the same boost pressures as before.
    Fix it, before it kills your 7m.
    cheers glen, i had figured as much.
    however i think i will get a less bent turbo in the interim, save hiflowing, rebuilding or upgrading for later.
    the good news is the noise is 110% definately not the turbo, and the alternator.
    thanks guys
    fit your current turbo with a larger compressor wheel, and at the same time, get a new sleeve bearing if possible... balance, and call it a day, an expensive day
    i've considered that, but at the end of the day ill only be running 12psi (for higher i'd want to redo the headgasket again) so it'd make little difference...
    Fava beans and chianti Backyard Mechanic AE86slut's Avatar
    New South Wales
    Just thought I'd add that a leaky manifold-to-turbo gasket can create an odd squealing sound as well. Not sure if that helps, but it might be worth looking at.
    Jeremy.
    I am not a doctor, or a mechanic...
    A.K.A Otomoto
    All new - Fart!
    Quote Originally Posted by Vios-GT_07
    it was 10,000 kms b4 it saw the red-line.. but even then i seldom push it that hard unless i have to prove a point i.e. competition
    12psi @ what rpm?... ill wait for matt to chime in.
    Western Aus
    My turbo has damaged fins, the turbo is a fair bit lagier than it was before it happened, more noticible when i turned up the boost from the stock 6.8 to around 11-12 psi.
    my fins are pretty badly damaged, but i have a spare ct26 sitting here waiting to go in.
    and i havent sxperience any squealing sounds of any sort, but youve already said that your sure its not the turbo so yeah.
    basically, since the fins have been damaged, ive only experienced a bit more lag, and the turbo runs out of puff and i can see boost drop off higher up.
    thats it though, no other signs.
    yes, i know its a ticking time bomb before it blows up, but the new turbo will be on soon.
    Eldar.O.
    Last Post: 11-10-2014, 12:02 AM
  2. tips for turbo manifold design
    Last Post: 03-05-2009, 06:47 PM
  3. Suspension for dummies
    Last Post: 13-09-2007, 07:38 PM
  4. Damaged turbo
    Last Post: 28-04-2006, 07:42 PM
