Results 1 to 4 of 4
Thread: AE86 vs TA22 LCA
    Less cheese than a Grease Monkey andurils_sheath's Avatar
    Default AE86 vs TA22 LCA
    Just a quick question,
    is the AE86 lower ball joint the same as a TA22??
    Im wanting to fit some of the T3 negative camber RCAs to my TA22, however Im not sure if the ball joint has the same spacing, and if the little nuckle things are the same size.
    Any help will be much appreciated and rewarded.
    Default Re: AE86 vs TA22 LCA
    seems i have answered my own queston.
    According to the whiteline catalogue they have the same part number which i guess means they are the same as i had guessed.
    south australia
    give yourself some rep now
    Victoria, Mt Macedon
    While I think the major wuestion has been answered (yes AE86 and TA22 share strut bolt spacing and bolt size) the location of the balljoint in the steering arm and the nut which holds them together is slightly different.
    A set of RCAs which fitted my AE86 fine had to be "modified" to fit a friend's TA22 as the nut fouled on the edge of the hole in the RCA. Though hopefully those making parts for a living would know this and make the hole big enough to suit either.
    Hen
  1. TA22 Facts and specifications
    By TheToyman75 in forum Tech and Conversions
    Last Post: 23-12-2021, 10:15 AM
  2. TA22 Diff Removal and AE86 LSD install
    By GeneSPIDA in forum Tech and Conversions
    Last Post: 16-10-2007, 12:58 PM
  3. Building an Australian RA21 (18RG + TA22)
    By ace in forum Tech and Conversions
    Last Post: 04-07-2006, 09:09 AM
