Results 1 to 12 of 12
Thread: stock celica trailing arm length
    Default stock celica trailing arm length
    Hi guys,
    I am in the process of sorting out the rear end in my 28.
    Could someone let me know what the stock upper trailing arm length is from centre to centre?
    Im sure there is either one laying around someones shed, or there is a celica on stand with stock ones that can easily be measured.
    Unfortunately (well it was good...) mine are modified, so i have no idea how far they are adjusted compared to stock.
    Stew
    Default Re: stock celica trailing arm length
    bump ...
    someone must have a stocker????
    These are the rough sizes that I sent T3 (they made up adjustable ones to suit).
    Hope they help.
    Timbo
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
    thanks mate 100% what i was chasing!!!
    Did you get rose joints both ends? he did say he had tem there to suit a 28 lol... i guess that was from you!
    Stew
    probably was me, lol. Yeah, both ends of all rods have adjustable/threaded spherical ends.
    His rod-ends have a smaller width than the 40mm mount on the celica (obviously), and a larger diameter than the 14mm bolt. So he supplies machined 'bushes' to fit. He actually supplied me AE86 ones the first time round, and an AE86 length swaybar... but as soon as I sent him an email he sent me out replacements immediately. They fitted perfectly.
    Timbo
    Current rides...
    2) White RA25ST
    i was looking at some that had bushes on the car ends of the rods.
    to prevent trying to tear the mounts on the car under diff roll... have you driven yours much with them installed? like/dislike? did gabe make the adjustment right in the middle of those measurement?ie you can go longer or shorter from there?
    Hey man, sorry I took so long but I finally sat next to my car and took some measurements.
    I measured 245mm on the top arms and 475 for the lower arms. Used a tape measure and eyed it off.
    So it seems ae86 and ra celica are same length wise. I knew celica was m14 bolt on the trailing arms(m12 for corolla) but wasn't aware of different spacer widths, celica being 40mm and cororra, 50mm.
    thanks guys,
    on the spacer widths - i was looking under my car and i think they may be the same still. Though the metal part of the celica ones are 40mm, my upper arms that have poly bushes in them are 50mm wide over all - ie the inner space of the moun t points is 50mm.....
    now to make the decision... Go with the battle version ones with the bushing at one end - but these will require machining of spacers to drop the bolt size from the celica m14 down to the sprinter m12...
    or go with the rod ends at both ends, and risk the prob of damaging the mount points on the car.
    Unfortunately the AJPS coilovers wont fit (according to them anyway...) and neither will their traction brackets.... which was dissapointing...
    wish it was easier....
    I haven't actually driven mine yet. Car has been in the shed with a BHG for ages.
    Current rides...
    2) White RA25ST
    Quote Originally Posted by Toy77 View Post
    thanks guys,
    Yeah, I measured 50mm at outside of bushes/inside of the upper metal brackets.
    Other way round, you need to drill out the 12mm hole in the spacers/sleeves of the BV arms to 14mm.
    The other option is to make your own stuff.
    bushed ends - Rod Ends
    spherical type m14 - Teflon® lined - 14mm x 2.00 RH - Rod Ends - Suspension Components - Chassis & Suspension - SummitRacing.com can get in in bigger than m14 and sleeve it down.
    Polyurethane - Polyurethane - Rod Ends - Suspension Components - Chassis & Suspension - SummitRacing.com
    Bushing - Bushing - Rod Ends - Suspension Components - Chassis & Suspension - SummitRacing.com
    Buy 3/4 or m14 threaded bar stock or get some made.
    You mean the height adjustable spring perches right? Traction brackets are easy to make anyway.
    Or if you don't mind bush/bush you could buy whiteline adjustable arms. Another option is to put 90a durometer AJPS bushes into stock arms to decrease bush delfection but cut them in half, thread them left and right handed and get a turnbuckle adjuster made up to do the adjustment. Whichever is cheaper for you.
    Low rep Grease Monkey
    Apr 2010
    bkk
    i think techno toy tuning has some adjustable pillo ball joint trailing arms for sale
  1. AE86 Lower Trailing Arm Length?
    By ballpencil in forum Tech and Conversions
    Last Post: 07-03-2011, 03:17 PM
  2. AE86 upper trailing arm length
    By HIZOKU in forum Tech and Conversions
    Last Post: 10-10-2009, 02:05 PM
