Results 1 to 11 of 11
Thread: Battery Charging Circuit & Checks
    Default Battery Charging Circuit & Checks
    I have noticed there's been numerous posts over time questioning if there's an issue with the alternator not charging properly.
    So, I did some digging around and found some diagrams that may help you see what the actual charging circuit looks like, but also some quick and simple ways of checking if the alternator and/or voltage regulator are operating within their specified limits.
    These are from a 1977 service manual for the 18R - so it should be helpful to most, if not all, 1st gen Celica owners.
    I also have the information in how to pull apart and check the diodes in the alternator but I didn't include that as I assume if the following measurements show your alternator to be stuffed then you'd get it serviced, as opposed to pulling it apart and fixiing it yourself. However, for the more gung-ho home mechanics, please let me know if you want this information and I'll put it into this thread.
    I made these into thumbnails for those with 56K and also so you aren't shocked with overly large images.
    Hope you find the following useful.
    This is the cct if you have an external alternator regulator
    This is the cct you have if you have an internal regulator in your alternator
    Vehicle inspection
    Alternator Inspection
    External Alternator Regulator Inspection
    Oh, in Fig11-24 the plug on the alternator is... E at the top and the two vertical ones is F on the left and N on the right.
    seeyuzz
    river
    Last edited by river; 31-07-2006 at 01:48 PM. Reason: Turned the pics into thumbnails
    Default Re: Battery Charging Circuit & Checks
    Good post River.
    i am a Backyard Mechanic WiLo's Avatar
    You must spread some Reputation around before giving it to river again.
    good post, it has actually helped me work out what the wiring in the mini is for
    Hey!!!!! So it works for a mini!!!!
    That's cool
    seeyuzz
    river
    Mate, You're a champion!
    This was exactly what i needed last week, and even though i just swapped to some unknown late model bosch jobby, this is very interesting to understand.
    When i get permanent net access i'm looking at doing a comprehensive write up/document of the RA28 electronic system with piccies and wiring diagrams. I've had to troubleshoot nearly every part of it on my car which was difficult at times without a wiring diagram, so hopefully it might help others out who aren't as electrically minded. I think i'll have to call some favours from ppl with circuit diagrams in a couple of weeks.
    Would rep you River, but have to share the love. Plus, you don't need any more rep anyway
    Timbo
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
    No wukkers. Besides, you're right, I got more rep than an 18RG!!!!
    Looking forward to your write up.
    seeyuzz
    river
    Quote Originally Posted by river
    haha... at least you deserve it
    j/ks
    Current rides...
    2) White RA25ST
    Good write up River. It also notable that nothing has really changed on the actual way alternators work other than their design so this will help more people out than you think.
    +ve - LeeRoy
    edit:
    Sorry River
    Here is some good info on alternators also:
    Wikipedia - Alternator
    Understanding Alternators
    Alternators and Regulators + general elictrical theory
    Some good info in these links so get reading.
    In basic, alternators produce alternating current whereas generators produce direct current.
    Alternators are also more efficient than generators in producing electricity but cars run on DC (direct current).
    This is where diodes come in. Diodes only permit current to flow in one direction which allows an alternator to be used by changing alternating current into direct current. However, because half of the electricity is being rejected due to being the wrong direction the output wave is a series of pulses, but due to the speed of these pulses, the current produced appears to be a steady stream of DC.
    Now since an alternator is designed to charge more than the maximum usage a car would have it will eventually fill the battery up with all the electricity it can hold and if it keeps charging it will damage the electrical system. This is where a voltage regulator comes into play.
    Since an alternator works by having its magnetic fields produced, the amount of current produced is determined by the strength of the magnetic field. In order to control the current output, this magnetic field is switched off when the electrical system is full of charge, and turned back on when it begins to fall resulting in the voltage regulator controlling the amount of current produced through switching the alternator on and off.
    The ign post on the alternator is also a vital component in the charging system. When the ignition is turned on, a signal is given to the alternator to give it the OK to charge. This is here to only allow the alternator to charge while the car is running as the electrical system can be damaged if the car isn't running.
    The battery light on the dashboard is also another thing to look at. This light looks at the voltage the alternator is producing and due to the importane of electricity in your car, will switch on to warn of an implending problem with your charging system so you don't get stuck somewhere.
    If i've missed something or something is wrong let me know and ill add/fix it
    - LeeRoy
    User Conversion King
    NWA
    which wire on the back of the alternator can i join to +12V to get full charging?
    ive done it before as a roadside fix on someone else's car and i think it is the N pin.
    someone is using my car and its not charging, they are 400km away.
    ive found its usually the regs that play up, not the alternator
    anyone care to confirm this for me?
    hello
    Has a pet Grease Monkey
    Nov 2008
    Netherlands
    if you want 20 blown light bulbs, a boiling battery stripping your paint and a blown ecu as well as the blown alt/reg, you should definitely do that. 18-20 volts easy!
    OTOH it's probably safe because not charging at all is usually the brushes. Jumping 12V to that won't do any damage (or good).
    Banging the alt with a hammer does sometimes help to get you home BTW, if it's the brushes.
    EDIT: oops old post... oh well...
    '73 TA12 Carina - pushrod power project
    '77 TA14 Carina - 1GGTE swap in the works
    '77 TA23 Celica - 1UZ swap abandoned, selling shell to someone with JZ plans...
  1. St18x : Rearmounting the battery
    By Classique71 in forum Tech and Conversions
    Last Post: 07-02-2007, 12:03 AM
  2. charging voltage
    Last Post: 04-01-2006, 11:21 PM
