Results 1 to 9 of 9
Thread: KE55 keeps blowing rear globes!! Help!!
    Low rep Grease Monkey
    S.A
    Default KE55 keeps blowing rear globes!! Help!!
    Gday!! A guy here at my work has a KE55 that just keeps blowing globes in the rear lights. It sometimes blows the fuse and then sometimes only blows the globes.
    Thats really the only info I have at this time, but I will try and find out some more.
    Has anyone had this happen to them at all??
    Any help would be appreciated.
    Regards, Ben.
    i am a Backyard Mechanic WiLo's Avatar
    Default Re: KE55 keeps blowing rear globes!! Help!!
    well if its blowing fuses aswell have you checked all the wiring for shorts?
    blowing globes.. perhaps the lights are leaky and water gets in when it rains and cracks the bulbs (had this happen before)
    or he has old bulbs buy some good ones and stop driving on rough roads?
    as for fuses, thats a different story... too much current is being pulled, probably due to a short or faulty wiring (wire worn through and touching body somewhere?)
    Sometimes if the engine earth strap isn't connected properly or has a poor connection all sorts of electrical issues rear their heads
    - LeeRoy
    S.A
    Ill ask him about all of these things guys, and let you know. Thanks for the advice
    Viagra Enlarged Member Grease Monkey TRAV-KE55's Avatar
    Probably not much help, but my old boss always said to me, never buy a light globe that doesnt have a manufactures name on it, if its not good enough to put there name on there product its not worth using.
    Maybe your mate is using $2 shop globes??
    Trav
    Active Corolla abuser!!!
    Travis Robson
    0418 552 413
    Montrose
    Maybe his car has been learning old tricks from Commodores?
    voltage regulator working ok? check it with a multimeter to be sure, though i think cars of your vintage (no offence) struggle to put out 14 volts anyway
    www.vicdrift.com
    now targeting: targets
    formerly shinybluesteel
    checked his blinker fluid???
    (heh heh, just to see the look on his face )
    By The Witzl in forum FAQ
  2. Toyota Part Numbers - Toyota PN# for common stuff
    Last Post: 23-05-2011, 09:54 AM
  3. KE55 Rear Drums to Disks
    By cibvr4 in forum Tech and Conversions
    Last Post: 26-01-2006, 10:50 AM
