Results 1 to 11 of 11
Thread: 1G-GE Tune up specs.
    Tasmania
    Default 1G-GE Tune up specs.
    Hi all just looking for the full tune up specs for my recently aquired toy.I have got a 72 MK2 Corona which has a 1G-GE fitted.
    Cheers Brett.
    Default Re: 1G-GE Tune up specs.
    Hey mate, how does the 1GGE go overall? I have one sitting at home I was thinking of dropping in my 4runner.
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    Tasmania
    Ive only drove the car a coupla times since I got it cause its got no reg but for what it is it is awesome.Power is unreal rite through the rev range.Revs to 7500rpm without a problem at all.And seems to be pretty good on fuel also.Ive owned and drove some pretty wild cars but for what the 1G goes like it is unreal.
    Cheers Brett.
    Quote Originally Posted by TurboRA28
    http://www.toymods.net/forums/showthread.php?t=10337
    refer to that thread and do a comparison.. of HP and torque figures to see if it's worth it.. IMO the 4 runners were under powered, with the 2.4 petrol motor.. best bet is to fit a V6 in it, u can't go wrong.. 1MZ (i think it is) or so.. the quad cam 24 valve thing..
    Thanks all.. Sorry should let this thread get back on topic
    Joel
    Hung like planet Pluto... Backyard Mechanic Rcubed's Avatar
    QLD!
    Valve Clc [cold]
    In 0.15-0.25mm
    Ex 0.20-0.30mm
    Plug
    gap 1.1mm
    ND Q20R-U11
    NGK BCPR6EY11
    same as v6 camry
    Idle 800 ±50 RPM
    Ign timing
    10° ±1° with short circuit T1-E1 using service connector
    > 12° @idle no short
    idle CO 1.0 ±0.5%
    compression
    178psi
    min 142psi
    max difference 14psi
    Tasmania
    Thanks for that RA 28 much appreciated.
    +rep coming your way.
    Cheers Brett.
    The biggest tune up will come from removing the throttle body and ISCV, and thoroughly cleaning them with carby cleaner, get all the built up goop on there.
    Also replace every rubber hose on the top of the motor that has gone hard or has cracked.
    Tasmania
    Yes I have noticed that some of the hoses are a little bit worse for wear.I had thought of removing the throttle body and such and see whats in there.Plus I still need to give it a good degrease so I can see what lurks under some of the scum thats built up on the engine.But really guys I can not get over how much grunt this standard 2litre has its awesome.And i've owned quite a few modded cars in my time.
    Cheers Brett.
    The 1G is a very neat little package for its size/weight.
    Surprises a lot of people.
    We had a 1983 1GGE pull 110rwhp at our dyno day last year.
    Sure it only has 130,000km's on it, but it is 23 years old.
    Tasmania
    Yes it is a very suprising little package as we know what all Toyota engines are like.And I have owned quite a few in the last 20 odd years.I'd near say that is what mine is possibley pulling at the rear wheels also.Frying the tyres in the first 3 gears is not a problem either.And I think it is only running a T50 Celica gearbox also.I need to check that though.
    Cheers Brett.
  1. 4AGE - Advanced Specs
    Last Post: 27-11-2013, 04:25 AM
  2. 3t-eu injected 1.8L, Tunup specs, Anyone?
    By 77GZE in forum Tech and Conversions
    Last Post: 24-03-2006, 12:31 AM
  3. dyno tune
    By mideon_696 in forum Tech and Conversions
    Last Post: 06-01-2006, 08:58 PM
