Results 16 to 30 of 41
Thread: 4agze CAS into 4AGE
    Default Re: 4agze CAS into 4AGE
    Quote Originally Posted by nos4ag
    So what your saying BIGWORM, is for the average guy on the street, he could just take the leads off the dizzy and connect the original wires and he could just drive off??
    The CAS is cheaper as it is bolt in and drive off!! Pure and simple!!
    Why is everyone making an arguement out of this, I am just telling him about my experiences, thats all!!
    What I'm saying NOS4AG, is for the average guy on the street using the dizzy you already have and is already bolted in is much easier and cheaper than having to purchase a CAS.
    And yes, once the aftermarket computer being used is wired up, all you need to do is take the leads off the dizzy.
    I don't know how or why this has turned into an argument, what Witzl & I am saying seems pretty straight forward to me.
    Low rep Grease Monkey
    S.A
    What you have just said, YES, is pretty straight forward. But earlier in the thread you were talking about how you modified yours to work with the Autronic. Now what if this guy is not that mechanically minded and just wants something that everyone knows works and arnt that hard to find?? You have given your opinion, and I have given my opinion, so why are you two both cross examining everything athat I have said when I have said nothing wrong??? Crikey.
    S.A
    Nice engine bay in the Celica by the way, at least you have actually painted the engine bay, not like some!! Just my opinion!!!
    S.A
    Thanks for taking rep from me "buddy", for no reason!!!! Childish, very childish!!
    yeah but this guy is using a Microtech, so he doesnt have to modify the internals of the dissy like Bigworm here did.
    Literally plug and play with the microtech - just add 4 coils.
    ...... butt scratcher?!
    Ok guys even though its turned into an arguement. Your info is very helpful for me(not being the original thread maker) Thanx guys.
    S.A
    Thanks Cuzzo (even though I dont know if it was my info that helped you)
    I didn't neg rep you, I don't know who did but it wasn't me. If I did (or later decide to ), your rep would drop alot more than it did. Unlike you, because I'm a member I can see who reps me, so thanks for jumping to conclusions & -ve repping me. Lucky for you I'm not the type to neg rep someone just because they neg repped me.
    Glad you like the engine bay, I did spend a bit of time on it!
    S.A
    BIGWORM, I negative repped you because you were arguing my opinion on the thread to do with the CAS for NO reason. People have done it to me before for less.........
    Someone has just taken another point of me now for NO reason.
    I guess nobody likes any NOS with thier 4AG tonight?!?
    Ah well, time to go to bed.
    Whatever! I didn't agree with your opinion so I tried to get a better understanding of it & tried to explain my opinion so you could understand it. If you think that warrants a neg rep then I'll gladly send some your way if you want.
    If you're going to neg rep everyone you disagree with on these forums you'd better be prepared to cop some neg rep yourself.
    I'm just not the kind of person to give out neg rep unless I really feel I need to, and if I did I'd certainly give my reasons.
    S.A
    Hmmm....
    1. I fully understood your opinion.
    2. I didnt disagree with your opinion, I just gave my own and you and Witzl argued it.
    3. I am not the type of person to give people neg rep either, but if you argue with me for no reason and take the thread to nowhere then you will get some from me. PERIOD.
    Lets just end this ARGUEMENT right now!!
    Anyway, 45aken, I still think that the GZE CAS is the best way to go for your application. (my opinion). But if want to do the dizzy mod, its all up to you mate. You dont have to use the GZE coils, just get some new ones from Bosch like Bigworm said too. They look nice and new in his engine bay aswell. Also the GZE CAS doesnt stick out as much, in case you have some difficulty with room with a turbo conversion or something. (again my opinion).
    Hope that I have helped 45aken.
    Who da F%^k is Takumi?? Backyard Mechanic 45aken's Avatar
    the second pic down is my actual car (trust turbo/external gate) i had to remove to cap to tighten the bolts haha. i was worried about how much the dizzy sticks out and just wanted something simple to fix all this (the car has been off the road for like 7 months getting everything done to it) if i can find a gze cas i'll just use that, it's alot neater etc. but if i cant then i'll just have to mod the dizzy then make a cap.
    im wiring up the ecu and i've done all the work on the car myself, i just want everything to work right the first time.
    is there any disadvantages when mod'ing the dizzy? in regards to accuracy etc? i haven't even had time to look inside it.
    BTW guy's i dont have a smallport dizzy, it's a bigport (if it makes any difference)
    AE86 - coming soon to a quiet mountain pass near you...
    WRX - currently epa'd...
    Is it possible to remove the rotor? Or as i read on the old forums "Just cut it off flush" then make a cover. What should i make a cover from?? It cant be flat.
    Toymods Club Member Backyard Mechanic Big T's Avatar
    Quote Originally Posted by 45aken
    Yeah it will be a little different. You'll have a 4 toothed wheel instead of the single the smallport one has. You can do as Bigworm has and grind 3 teeth off but check if your ecu can run with the 4 tooth wheel 1st.
    Eddie.
    4agte finally completed. 234rwkw @ 8125rpm. Tis fun
    Quote Originally Posted by slide86
    i think 4age has a hall effect type sensor (correct me if im wrong). make a plate to cover it and a gasket. then you will have a CAS that you can use on the microtech.
    nearly right - the sensors are VRs (variable reluctors).
  1. 4AGZE in to 4AGE AE82. (now with CV shaft info)
    By Striker in forum Tech and Conversions
    Last Post: 28-12-2006, 02:53 PM
  2. 4age fuel pump for 4agze
    By dug in forum Tech and Conversions
    Last Post: 30-06-2006, 07:10 AM
