Results 1 to 7 of 7
Thread: Hi ace G series to JZX90 G series CWP
    Forum Sponsor Grease Monkey
    Default Hi ace G series to JZX90 G series CWP
    I have a customer with a hi ace with G292 (4.1 open) diff. I have a 3.9 ratio from a JZX90 . Will the crown wheel and pinion from the JZX go straight into the hi ace carrier or is there likely to be bearing differences.
    Andrew V
    Central Vic Auto Parts
    Forum sponsor
    www.cvap.com.au - Have a look
    [email protected]
    Ph 03 58 231911
    Viagra Enlarged Member Grease Monkey TRAV-KE55's Avatar
    Default Re: Hi ace G series to JZX90 G series CWP
    Andrew,
    Im sure you have allready looked at this bit, but from memory (yes yes i know.... Hows your memory Trav!!) the JZX90 is IRS and isnt the the pinion quiet noticably longer (even when veiwed from external) than the hi-ace diff??
    Trav
    Edit: i just realized im thinking supra (JZA not JZX), which leads me to think i have no idea what the hell im on about because i dont even know what a JZX is, is it a aristo or chaser or something other with a 1jz or 2jz engine??
    Trav (dipshit)
    Active Corolla abuser!!!
    Travis Robson
    0418 552 413
    Not a direct comparision.. But F - series pinion gear is the same between the IRS & live axle models.
    Sorry cannot help with G.
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    Thanks for your wealth of non knowledge trav .
    I think I will have to pull them apart to check
    Andrew V
    Forum sponsor
    [email protected]
    Ph 03 58 231911
    vic
    Remember there is 4 diff pinion bearings the g series use 2 are the same size just more rollers in them , early and late thing.
    Dave
    yeah the open hiace/ hilux diffs use a 2pinion, but the lsd models use a 4 pinion...as do the jzx90s/ surpas etc
    vic
    We are talking about the bearings not the spider gears pinion shaft.
    Dave
  1. Guide: How to build a K series motor
    Last Post: 19-10-2007, 09:43 PM
  2. What torsen center is this? (10 bolt)A or G series? Pics**
    By 07XTC in forum Tech and Conversions
    Last Post: 29-12-2005, 06:14 PM
  3. Guide: How to build a K series motor
    By oldcorollas in forum FAQ
    Last Post: 26-09-2005, 08:51 PM
