sounds like it had a non-recovery cap on it before..
maybe coolant? sounds like its *NEARLY* cooking when you are running it (i assume its got an engine fan?) and then when you stop the coolant is getting just hot enough to boil.. some anti-boil might put it up high enough to stop this?
you could also check that the overflow hose seals to the filler neck to make it suck any vented coolant back in..
 Cooling issues...
 Cooling issues...
