Results 1 to 15 of 15
Thread: sump off to change rear main seal on 1ggte?
    User Conversion King
    NWA
    Default sump off to change rear main seal on 1ggte?
    i will be replacing the rear main seal on the 1ggte soon and i have a feeling the sump needs to come off to do it. i think there was 2 bolts on the inside of the engine that need to come off?
    so who has done it and can remember??
    thanks,
    brett
    hello
    Default Re: sump off to change rear main seal on 1ggte?
    Only the flywheel/clutch has to come off. I should know, i've done it 3 times
    Who's done it 3 times ?
    (lets just not mention who's fault it was)
    We've done it once, you did it once, and I did the last one. Which one worked?
    Haha, mainly because of the amount of time spent with wet and dry to ensure a perfect seal
    I put the first one in.
    I pulled the first one out.
    I put the 2nd one in.
    I pulled the 2nd one out.
    You tidied the crank,
    I put the last one it coz you didn't want to.
    I swear I put the last one in and just got you to check it?
    Possibly.
    But I seem to recall you not wanting to do it.
    Unless it was actually me not wanting to do it coz I said if it leaks again its your fault?
    Meh.
    vic
    Has a genuine seal been used, non gen seals are shit .
    D
    Genuine? Toyota seals? hahahaha
    You mean NOK seals?
    The 2nd one put in was a RANCH seal. That looked crap.
    But the 3rd one was a quality seal, name escapes me right now.
    NWA
    thanks for the help
    +rep dished out.
    up to 501 for cruzida
    hello
    NWA
    quick one,
    ive never replaced one before, the whole aim is to get that part of the crank smooth as possible? fine grit sandpaper?
    *hovers mouse over cruzida* "cruzida listen to this one"
    doesnt really make sense though, it could do with a comma i think
    hello
    That part of the crank should not need touching, unless you scratch it while removing the seal.
    Because when I put the first new seal in, (I put it in way too deep), to remove it took a lot of effort and force.
    If you only put the new seal in the same amount as the current seal is, you will not have this issue.
    Just give the crank a good wipe after you remove the first and feel for any nicks and gouges.
    NWA
    awesome.
    sounds good
    hello
    Quote Originally Posted by cambelt1
    D
    Haha, I concur with Peewee, genuine seals are made by NOK And they're a lot cheaper from a bearing place than Toyota A LOT.
    Canada
    After removing the old seal, before putting the new one in, it is also a good idea to clean any varnish or sludge off the end of the crank.
    Carb cleaner can be used for this. Fine emery cloth can also be used, but only "sand" it circumferentially (direction of rotation of the crank)
  1. Toyota Part Numbers - Toyota PN# for common stuff
    Last Post: 23-05-2011, 10:54 AM
  2. 22re leaking from rear main seal.
    By ra65 in forum Tech and Conversions
    Last Post: 24-12-2005, 10:27 PM
