nicked from here http://www.woodworkforums.ubeaut.com...hp/t-6734.html
it should be able to do high volume even with a lower pressure... as it's the volume of air, not the pressure, that makes it work the way it does...Gun set up involves balancing air pressure at the tip centre, with air pressure at the tip horns, with fluid delivery. If you were to point the gun at a piece of card, with the gun arround 20cmm from it and pull the trigger briefly, with paint in the gun, you should see the paint form a fat cigar shape. This indicates that the gun is set up correctly. If the shape is an oval this would indicate that there is not enough air pressure at the horns. if the pattern is split or narrow in the middle, this indicates that the air pressure at the horns is too high.
A good start point for set up would be:- Fluid 2 turns out from fully closed, Fan control (Horn Pressure) half open from fully closed. Air pressure really depends on the type of gun you are using, HVLP 30 psi inlet, RP 30-40 psi inlet, Conventional (high Pressure) 40- 65 psi inlet.
