Results 1 to 10 of 10
Thread: 4 two 5 stud conv
    KiwiCruzn Grease Monkey supra7m8u@yahoo.com.au's Avatar
    new south wales
    Default 4 two 5 stud conv
    Hi guys im just about two do the 5 stud conv on my ma61 useing crown hubs Ive used the search thread but its not bringing up what i wont.I no there was a guy that had the full thread of his conversion on here it was a long time ago.Can some one send me the thread if they no where it is that would be great.And i hope ive posted this in the right section cheers guys
    Default Re: 4 two 5 stud conv
    Is there something specific you want ?
    Chances are the pictures in that old thread are no longer hosted.
    new south wales
    I would like two no which brake calipers i can use i no skyline ones can be used not sure weather they are the gts or gtr.Do i need mounting brackits for these and if so where do i get these made . Which rotors i can use ive heard ford but dont no which model ford i can use.And after the conversion is complete does this change your off set.cheers
    The MS65 hubs will give +2mm per side by themselves. Any floating disc conversion (skyline or BA) will give a further +8mm per side.
    Brake conversion is exactly the same as 4 stud, but the spacer needs to be 2mm thicker to cater for the extra offset in the MS65 hub. The MS65 hub centre is also 67mm as opposed to the MA61 hubs 60mm. Skyline hub centre is 68mm and BA is 72.1 from memory.
    Have a look at the xA6x brake thread I started for some pictures.
    (BA = BA Ford Falcon)
    new south wales
    Thanks CrUZida 4 your help mate.
    Tasmania
    I have the full conversion on my computer but unsure how to upload it.
    It does have the link if this helps www.eds.au.com.If you type it in it will come up as a windows live search but it is there.
    Cheers Brett.
    new south wales
    Hi andrew thanks 4 your help mate but could find it.Is there any way you can send it two my email cheers jason
    new south wales
    Thanks CRuZida your a halpful guy two have,Also who dun the targa and what prise range are you looking at four something like that Ive always liked that look.cheers jason
    Jan 2016
    I know this is an old thread. But i have done some searches and couldnt find out what u was chasing. Is there any difference in the ms65 hubs thru the years or are they all the same. I was reading on another thread they were chasing a 1972 model for the hubs. Or dose it not matter.
  1. TA22 strut brake upgrade/5 stud conv
    By vkboy in forum Tech and Conversions
    Last Post: 24-02-2008, 05:16 AM
  2. Stud patterns
    By DQIKST in forum Tech and Conversions
    Last Post: 21-04-2006, 09:55 PM
