Results 1 to 5 of 5
Thread: Part number for Blacktop 02 Sensor (generic bosch no or similar)
    Jun 2006
    AUCKLAND
    Default Part number for Blacktop 02 Sensor (generic bosch no or similar)
    Hi Guys
    Just wanting to know what the part no is for the four wire O2 sensor is for a blacktop 4age.
    I got a half cut and it didnt have one in it, so i cant compare it to anything to see if it is the right one.
    Did a search and didnt find the answer anywhere. So hopefully someone out there can help me.
    Chiba
    Default Re: Part number for Blacktop 02 Sensor
    89465-19685
    Forum Member Grease Monkey ap7's Avatar
    Hey you wanna get rid of the empty shell from the front cut assuming its an AE111?
    Only problem is that I am in Sydney and am not sure how much freight will be.
    Any idea on freight and how much would u let the shell go for?
    Jun 2006
    AUCKLAND
    Hey guys, thanks for that but i was acutally looking for the generic bosch number or similar so i can get one from somewhere that isnt toyota.
    Oh What a Feeling! Backyard Mechanic c2888's Avatar
    Default Re: Part number for Blacktop 02 Sensor (generic bosch no or similar)
    http://www.bosch.com.au/content/language1/html/4566.htm
    I reckon it's this one, but I could be wrong seeing as i've just guessed it'll be similar to a avalon or any of the late toyotas with a 4 wire.
    0 258 986 606
    Section A shows you types and how to fit
    Scetion B shows you part numbers and model/make info
    I found a brand spankers in the box of o2 sensors at the wreckers I used to work at, must've been dead stock from one of the toyota dealerships. Plugged straight into my 20v loom, and no more codes. Gotta be happy with that.
  1. R154 speedo transducer part #- help!
    By Esselte in forum Tech and Conversions
    Last Post: 09-01-2009, 03:20 PM
  2. R154 electric speedo sensor part #?
    Last Post: 07-09-2007, 04:58 PM
  3. Part number for single wire O2 sensor for 3sGTE??? Problem solved
    By worldwalker in forum Tech and Conversions
    Last Post: 24-07-2007, 06:32 PM
  4. 1UZ-FE part number ID and help needed
    By scootaphill in forum Tech and Conversions
    Last Post: 09-01-2006, 04:26 PM
