Results 1 to 10 of 10
Thread: why dosent the 1G bellhousing fit my 2tgeu
    0402727834 Grease Monkey turbo ke20's Avatar
    Default why dosent the 1G bellhousing fit my 2tgeu
    well ive sourced up a w5x box and i went to sss automotive for the 1G bellhousing. now the problem is the only holes that bolt up are the top 2 centre ones. have i been given the wrong bellhousing or is there something im doing wrong?
    ive had to remove the dowels as they didnt line up either.
    do i need the plate between the box and block of the 1G to make this work?
    well if worst comes to worst i know where a 3t housing is with a w series box is. But i thought that 2t, 3t and 1g are the same. i even got a 1g flywheel and clutch.
    what should i do???
    justin
    T'ville, QLD
    Default Re: why dosent the 1G bellhousing fit my 2tgeu
    AFIAK they should be the same
    i know the 1g and t series flywheel's bolt up to each other
    are you sure its a 1g bellhousing or is it a 3Y?
    2T out 4A in....
    Yup, should be the same so sounds like you might have a S or Y series BH?
    Justin,
    Looks like they have given you the wrong bellhousing. They are good guys so give them a call and I'm sure they will swap it over for you.
    1971 2T-B Celica TA22 ST.
    1975 2T-G Celica TA27 GT
    1985 3F Auto FJ62 Landcruiser
    All W series bellhousings will have a faint letter cast into them (about 5mm high, 3mm wide) on the edge of the housing (same face as the bolt goes in).
    You'll see a G, T, M, S, Y, R, etc.
    I may even have one for you mr justin you can have for nothing. Just need to check what engine its for.
    heres the comparison
    2T 1G
    cuzzo, if you could find out what one you have that would be tops.
    looks like i gotta wait for next weekend to take it back.
    thanks 4 all the help
    justin
    That looks very similar, but at the same time slightly different to the 1G bellhousing I had.
    Tasmania
    It looks a bit like an M bellhousing to me.It's definitely not a G series bellhousing.
    Cheers Brett.
    T'ville, QLD
    mmm it appears to be not even remotely close to a 2t bellhousing.... have a chat to them im sure they will see the error and promtly fix it
    2T out 4A in....
  1. A-series bellhousing to OLD T-series transmission
    By Toycrash in forum Engine & Driveline Conversions
    Last Post: 21-06-2008, 04:24 PM
  2. (TA22) 2T - 2TGEU conversion (now with pics)
    Last Post: 13-11-2006, 08:52 AM
  3. 2TGEU and 3TGTEU Pistons/Crank Question
    By GeneSPIDA in forum Tech and Conversions
    Last Post: 11-05-2006, 09:30 PM
