Results 1 to 14 of 14
Thread: Summer is coming - air conditioning question
    Perth, WA
    Default Summer is coming - air conditioning question
    Hi guys,
    summer is coming and I just installed an reconditioned air conditioning system in my daily. Any one knows where to it regas ( of course at the most cheapest price) in Perth area? Also, where to get the cheapest air condition filter?
    CHB
    Junior Member Automotive Encyclopaedia eeeyan's Avatar
    Sep 2009
    Default Re: Summer is coming - air conditioning question
    I have a mate that works for Burke Air which do hosuehold aircons and he regassed my old car for nix but i dont see him doing that favour to everyone.
    If you want the cheapest price ring a few places and play them off against each other NATRAD is one, just look them up and do some shopping dude.
    Wish I had a F#%ken awesome toyota.. saving for the goodness now.... stay tuned....
    Regas's are around the $130 mark, bit more if it needs converting from R12 to R134A.
    A new dryer is about $60 (incl installation).
    Not sure what you mean by filter (I presume you mean dryer).
    Places generally won't vary by more than $10 or $20
    Where they can vary though, is if the system leaks within a week or so.
    Some places will charge you the full regas price, others only half price.
    0402727834 Grease Monkey turbo ke20's Avatar
    what is it with people wanting cheap this and cheap that?
    buy a canary bird and and can sing "cheep cheep" all day long
    but as above regas vary from $100 to $130.
    you may find it for cheaper but i bet they wont have their aircon lisence
    reciever drier usually around the $50 then add labour on top to change it.
    being that you have a 2nd hand system make sure they put a leak dye in it otherwise when or if it has a leak it will be harder to find.
    PROWIRE PERFORMANCE WIRING
    Specialising in:
    -Haltech
    -Full Rewires
    -Engine conversions
    -Custom Air Con. Installations
    -Drag, circuit & show car wiring
    Justin Moore
    0402 727 834
    http://www.facebook.com/profile.php?...88667244568569
    Junior Member Automotive Encyclopaedia JZA70R_92's Avatar
    May 2008
    Where can a new dryer be obtained? also with this R12 to R134a where is this mod done? so far im using a MA70 recoed condenser and its fittings for R134 also 7m aircompressor had a blue fitting on it which I binned! currently using a factory jz aircomp! will that need to be changed?
    1992 - JZA70 STOCK - SOLD
    The R12-R134A mod is just replacing the gassing connections on the pipes with different fittings, preventing R12 from being regassed.
    There are places around that run HC12 (HiChill or similar) which doesn't need the conversion, but the parts are like $30.
    New dryers are available from Repco I believe.
    Feb 2009
    You also normally run a charge of r134a through the system wen doing a retrofit to remove the remaining r12 then dump that and change drier and charge properly
    Retro fit fittings are added so different gas arent put in. R12, r134a, fr12 etc all have different fitting profiles.
    134a has very stringent conditions for use, no top ups aloud or "it just needs gas" crap. Hydrocarbon gases hychill etc dont so expect someone that uses 134a to charge as more cost are invovled in licencing and so on.
    Feb 2009
    Double post....damn phones
    wa
    Isnt Hychill the one that was causing explosions?
    Also they are not supposed to use leak dye until all other methods of finding a leak have been used, and they are not supposed to gas a system if there is a possibility of a leak.
    Perth, WA
    thanks for the replies. now at least I know a regas will cost about $100 mark (whether or not it is license or not) and a dryer is about $60s mark.
    Cheers guys.
    Apr 2016
    usa
    You may contact to AC repair Cypress they are very good for regasing AC and are affordable and they provide adorable service.
    Jul 2007
    yeah um this thread is 6 years old mate
    Dec 2008
    Wellington, NZ
    Angry Re: Summer is coming - air conditioning question
    ... and pimping for a repair shop is SPAM !!! Get that shit out of here !!!!
    Feb 2016
    Quote Originally Posted by jondee86 View Post
    Need a good old Witchhunt.
    Get the pitchfork.
  1. 3S-GE Question
    By Darkhound in forum Tech and Conversions
    Last Post: 21-11-2006, 05:13 PM
  2. IS300 diff question
    By blueck in forum Tech and Conversions
    Last Post: 14-10-2006, 12:53 PM
  3. Radiator question.. Core thickness/air flow
    Last Post: 05-05-2006, 09:49 PM
