Results 61 to 74 of 74
Thread: Wakefield Park Track Day - Friday 30th of May!!
  1. #61
    Default Re: Wakefield Park Track Day - Friday 30th of May!!
    So what brake fluid do you guys recommend thats compatible with Toyota brakes?
  2. #62
    I don't think there's anything particularly needed special for Toyota brakes, it's not like the Toyota Red Coolant.
    I'm using a DOT6 racing fluid ($$$$), but my car isn't used on the street, so lasts a lot longer.
    A good quality DOT 5 should be sufficient. It's all I've ever run in the Dinas on the track.
  3. #63
    Quote Originally Posted by big_zop View Post
    Any performance/track fluid is an option. I use Motul RBF 600/660 - but it's quite exxy. Penrite does on in their Sin range that's still very good and a bit cheaper iirc.
    I'd suggest looking at the temp rating of all the brake fluids at a good auto shop (I like Autobarn), and pick the one that's best bang for buck - you don't need to pay the extra $20/L for those last 50 degrees of temp rating
  4. #64
    Jul 2007
    Penrite sin is now called penrite racing brake fluid. It is now of comparable performance to stuff like RBF660, but at much lower cost. Get either that or motul RBF600/660. Anything else will need multiple bleeds over the course of a day if you are using stock brakes.
  5. #65
    Oct 2009
    I would be fitting the highest temp full race pads, the best fluid you can buy and sentencing the rotors to death, I've got identical brakes on mine and whilst they work........ R33's were not known for having amazing brakes, toss in a heaver car with a 1JZ making more chop and your going to need all the help you can get.
    RBF660 is not that bad price wise, I got a liter of it for $60
  6. #66
    Oct 2009
    Garth - When is the next day?
    I've pulled the car cover off, started the motor, bought a 2 way LSD and ordered a heap of shit.
    Aiming to be ready 2 weeks prior
  7. #67
    Quote Originally Posted by dnegative View Post
    http://www.toymods.org.au/forums/sho...=1#post1559003
  8. #68
    Oct 2009
    Sweet, just before my birthday
  9. #69
    Jul 2007
    with any luck i'll have the adub there. shocks and bushes showed up yesterday
  10. #70
    Yep, 8th of August is the next one, second last one for the year! When i realised it was only two months off i thought i should get the next thread up, and suddenly it's two weeks later. Anyway, it's soon, so get organised.
    Rob: As promised, my Phillip Island turn 1 spin - outlap, 1st flyer, then it's the 2nd flyer starting at about 4:30;
    http://www.youtube.com/watch?v=ODnLig1mYmQ
    And here's the new thread for August;
    http://www.toymods.org.au/forums/showthread.php?t=83204
    Toymods Club Member
  11. #71
    hmmm, chances of me getting the engine conversion completed might be slim.
    Or at least I'll be running like the yellow Honda last time, with no cluster...
  12. #72
    ok, random electrical question.
    I plugged the Elantra wiper motor into the Excel loom tonight and it seemed to work properly.
    Conversely, does this mean that the Elantra wiring loom should make the Excel wiper motor work (which is what I need)?
    Now if only the Elantra wiring plugged into the Excel's indicator stalk, then I'd have a lot less trouble
  13. #73
    Jul 2007
    if it plugged straight in and worked then one would assume so yes
  14. #74
    I've been a bit lucky with some of the stuff.
    Wiper motors, radiator fans, headlights all have the same plugs & pins between the 2 cars.
    Gotta love the laziness of not redesigning stuff
  1. Wakefield Park Track Day - Friday 10th of May!!
    Last Post: 19-06-2013, 02:49 PM
  2. Wakefield Park Track Day - Friday 9th of November!!
    Last Post: 01-02-2013, 10:07 AM
  3. Wakefield Park Track Day - Friday 7th of September!!
    Last Post: 03-10-2012, 05:36 PM
  4. Wakefield Park Track Day - Friday November 6th!!
    Last Post: 04-01-2010, 02:10 PM
  5. Wakefield Park Track Day Friday 2nd of November!!
    Last Post: 06-02-2008, 05:22 PM
