Results 16 to 20 of 20
Thread: Toyota D4-S Twin Fuel Injection
    May 2010
    Moscow
    Default Re: Toyota D4-S Twin Fuel Injection
    done 4gr-fse off mark x grx120 into mazda rx-8, no dramas
    had complete wreck to strip all the needed parts off it
    just remember to have it serviced properly
    Aug 2012
    NSW, SYD.
    Quote Originally Posted by George View Post
    Got a build thread? Sounds awesome. Also reassuring!
    I'm taking it that you used the factory ECU and Drive-by-Wire pedal?
    Anything else to remember to take? I've been told immobilizer, push start ignition key antenna.
    Wouldn't know or have heard of anyone's experiences with aftermarket ECU and with the typical port and -FSE Direction Injection??
    May 2010
    Moscow
    sort of
    http://www.toymods.org.au/forums/eng...da-rx-8-a.html
    haven't been updating it since then though
    some more videos here
    http://www.drive2.ru/b/62165/
    some mark x's had no immobilizer , so that issue was sorted out easily. I had no technology to bypass it back in the time of the conversion, so finding the proper ECU was the only way to go.
    pedal wise, nothing fance, ran the 6 wires to the ecu as per wiring diagram
    the diagram for lexus is250 was good enough to help me with the mark x donor
    Aug 2012
    NSW, SYD.
    Cool, so with the right model the loom pretty much carries over.
    Do you know why some don't have the immobilizer?
    Is it a regional, year of production or abase-model/factory-option type thing? etc?
    May 2010
    Moscow
    Some JDM cars seem to have no immo or more simple system compared to same model for other markets. The same rule of thumb applies to production year - the older the year the simpler the security is
  1. 1FZ-FE fuel injection type
    By alanrlow in forum Tech and Conversions
    Last Post: 24-01-2011, 09:02 PM
