Results 1 to 7 of 7
Thread: TA22 + W55 + AUTO Tailshaft
    new south wales
    Default TA22 + W55 + AUTO Tailshaft
    Hi guys,
    Just wanting to get some opinions on the strength of a standard ta22 automatic tailshaft. Anyone experience any issues with strength, balancing? Any other issues I should look out for considering these are rubber filled shafts??
    Engine is a 2t/3t hybrid making just over 100rwkw, installing a w55, standard t series diff with Kaaz 2way lsd and 4.77 diff gears, using exedy heavy duty clutch kit.
    Nov 2009
    Default Re: TA22 + W55 + AUTO Tailshaft
    mine is making 110kw with a t50 and auto tailshaft and it seems to be holding up fine, no vibrations or noises so far
    new south wales
    Quote Originally Posted by ctrain View Post
    Why are you using an automatic tailshaft instead of the standard manual shaft? Did u have to lengthen it and change the yoke???
    Nov 2009
    Nah i just had to change the yoke, different spline count, no lengthing required, i converted mine from auto to manual so i had the auto tailshaft anyway, a manual one was pretty hard to find.
    new south wales
    Did u get the shaft balanced at all? If so did it balance ok?
    I took my auto shaft to get it serviced and balanced, new yoke as the existing one has rusted due to being exposed to the elements, new uni joints and a balance. The shop recommended that I use a different shaft as the rubber filled shafts don't balance properly and have durability and strength issues.
    Nov 2009
    I think its been balanced when the original owner had it cos its got weights on it.
    new south wales
    They are balanced from factory as mine also has balancing weights on it that look like factory work.. I just get funny about tailshafts and I might be getting a little over cautious due to my paranoia regarding tailshafts.
  1. ta22 auto tailshaft equivalants??
    By 79GT in forum Tech and Conversions
    Last Post: 29-02-2008, 12:17 AM
