Results 1 to 14 of 14
Thread: Mounting air fuel ratio in inlet manifold instead of exhaust?
    victoria
    Default Mounting air fuel ratio in inlet manifold instead of exhaust?
    Im tuning an engine for start up and was going to drop an AFR meter into it to get the starting mixture right, Just wondering if anyone has a good reason that the sensor should be mounted in the exhaust instead of the inlet manifold?
    The engine is carbureted so whatever is the manifold should be a pretty fair representation of whats going into the motor.
    Anybody have any idea why this could cause issues?
    Feb 2009
    FNQ
    Default Re: Mounting air fuel ratio in inlet manifold instead of exhaust?
    Don't wideband O2 sensors measure exhaust by-product gases (carbon-monoxide)??? My guess is it will read full lean all the time.
    Aug 2009
    That's exactly as I was about to write jb_22.
    Feb 2009
    FNQ
    Yay! got the hole-shot
    Surely you could guestimate a jetting setup for startup? Err on the side of being too rich if anything. What carb/engine setup are you tuning?
    dude, you need to look into how an O2 sensor works..
    basically, it needs to be hot, like 300degrees..
    it'sbasically an oxygen exchange cell, and it measures residual oxygen after combustion.
    putting it in the intake makes no sense... you may as well put a spark plug in your inlet manifold to ignite the micture before it gets to the engine....
    i realise this may be a troll post but just in case..... DON'T DO IIIIT
    Feb 2009
    FNQ
    You mean a trolla post
    Dec 2008
    Wellington, NZ
    Quote Originally Posted by jb_22 View Post
    Whaaaaaattt ?? Why do you think it is called an O2 sensor then ??? Wikipedia says it so much better... "The sensor does not actually measure oxygen concentration, but rather the difference between the amount of oxygen in the exhaust gas and the amount of oxygen in air.".
    Cheers... jondee86
    Nov 2011
    Raw fuel Might also fk it
    It reads gas not liquid
    Which is what the atomised fuel is in the inlet manifold
    Mixtures at idle can be done without meter
    Turn mixture screw in till it stops
    Keep turning it out till motor starts to rev nice keep turning till motor starts running a tiny bit rough
    Then turn it back way u came abit
    Do it afew times and u will get the hang of it
    Nov 2012
    Sabah
    Quote Originally Posted by jondee86 View Post
    Cheers... jondee86
    If I'm not mistaken the O2 sensor it self does not measure the oxy in the air. Only in the exhaust. And it actually measures the temp of the gas and converts this value to a pre determined display setting(A/F gauge).
    this is too painful
    hopefully this will settle the confusion
    http://www.ngk.com.au/oxygen-sensors...en-sensor-work
    Zirconia Sensors: An important property of the Zirconia element is that it can conduct oxygen ions above a temperature of about 350°C. When the sensor is fitted, the outside of the Zirconia element is exposed to the exhaust gas and the inside is in contact with reference air.
    Both sides of the element are coated with a thin layer of platinum that act as electrodes and carry the sensors voltage signal from the Zirconia element to the lead wire. At operating temperature, oxygen ions are able to pass through the element and deposit a charge on the platinum electrode thus generating a voltage signal.
    If the AFR is rich, a high signal voltage is generated across the electrodes due to the difference in oxygen concentration present across the two sides of the element. Conversely, if the AFR is lean, a low voltage is generated across the electrodes due to the small difference in oxygen content between exhaust gases and the reference air inside the sensor.
    Nov 2012
    Sabah
    Sorry jondee86 your correct. My mistake. Cheers. Nice post.
    Nov 2011
    Who bloody cares the description of the oxygen sensor
    It goes in the exhaust not in the inlet
    He is also using a carby
    How fking hard can it be to get an engine with one of these started
    Get your timing right
    Then turn on the fuel tap opps I mean carby and crank her over
    Screw mixture screw all the way in the come out two turns
    That should be good starting point
    Rev it and for start up u might want a tiny bit of smoke when u rev it
    This is a same setting to have a tiny bit of black smoke
    Then u know your not lean
    Or turn out mixture screw bit more to lean it off
    Jan 2012
    Finland
    This must be a joke..
    But.. the lambda compares the exhaust gas oxygen to the exterior air oxygen.The intake air has all the oxygen(20,9% of athmosphere) so the lambda can't measure anything.
    When burning rich mixtures the sensor comes as temperature sensor (because there is no oxygen to sense) and therefore is not too accurate in there.
    So,you CAN'T put lambda in the intake!
    Victoria, Mt Macedon
    Don't listen to everyone here, they're just jealous they didn't think of it. But to get best readings you definitely need an oxy sensor with inbuilt heater (3 or 4 wire unit) since it isn't going to be heated by the exhaust. The red hot sensor in the post-carb intake manifold will give very good results.
  1. Mounting o2 sensor. Where in exhaust?
    Last Post: 02-02-2010, 06:40 PM
