Yes it is worth buying the oversized valves. It will help.
If you know the history of the 2T head and it has not been shaved before (just plained flat) then you could take 1mm off safely to raise the compression ratio whilst you have it apart. You can get some good lift numbers even with stock pistons and from memory my 2T with stock pistons cleared easily 9.5mm lift. That cam reads like what I used to run in my 2T-2T-B motor (not the TRD parts motor). This acheived 74.5Kw at the wheels, drove real smooth and reved to 7500 with double valve springs and twin Mikunis.
Regards
Rodger
