Results 1 to 15 of 17
Thread: Oil cooler study , with or without thermostat?
    Jun 2011
    Default Oil cooler study , with or without thermostat?
    Hi guys,
    Been thinking to upgrade my oil cooler on the AE112R to aftermarket ones. Not to say genuine Toyota not up to job but looking to upgrade it so that I can run turbo oil feed, oil temp guage using the sandwich plate provided in the kit.
    After some "google" I found a interesting article posted by Ozhonda member, below is the link
    Oil cooler study, with or without thermostat?
    There is not much difference between the 2. What do you guys think?
    Jul 2007
    VICTORIA
    Default Re: Oil cooler study , with or without thermostat?
    Don't run a full flow on the street. I'm running a full flow cooler with -10AN lines on a 4age. temp only get to 70deg C on the street. On the track though is a different story.
    Use a water-to-oil heat exchanger, they are better in just about every way. One like off a 3SGTE would work fine.
    www.billzilla.org
    Toymods founding member #3
    Like the factory ones Bill? Like a sandwich plate before the filter with water lines...or is there an external option?
    -RM
    Mar 2010
    The factory water-to-oil cooler on my 3sge isn't much good on the track, oil temps get up to about 135-45 after maybe 7 or 8 laps.
    I don't know what my water temps are like though, the factory gauge never gets over half way but this probably isn't all that accurate.
    Pretty much all the serious 3sgte builds i've seen take the factory cooler off and use an air cooler.
    Quote Originally Posted by mullett View Post
    -RM
    Yep, though as mentioned above they aren't good with sustained high-power, maybe a WRX cooler like I use on my racing car.
    A little bit of fiddling to get it in there but it's well worth it.
    www.billzilla.org
    Melbourne Victoria
    i use the std altezza 3sge oil to water with a mechanical sender in the metal sump and after 12 laps at sandown it will be only sitting around 100c ,i have ran the car at wakefield as well about the same temp
    on a hot day at winton mid to high 30 c days ,goes up to 120 .
    when i had the dry sump set up on the oil temp was always higher .,more friction with external pumps and lines with a 20 row cooler go figure
    Forum Sponsor Domestic Engineer Bazda's Avatar
    Jul 2008
    Auckland
    You can use a full flow oil cooler with no thermostat, you would prob need a cover for street use so it gets up to temp better.
    Thats what I do anyway. Once you get to the track, take the cover off.
    Now 9AGTE 410kw atw
    Jul 2009
    No experience running one yet, but for cost comparison I held out and found a G-rex thermostat sandwich plate, trust cooler and speedflow lines/fitting for from a race car for less than the cost of a china spec relocation kit without thermostat.
    I was about a week off buying the china one too. Really happy with what I got though, nice solid plate and the cooler is a moster.
    NICE VIBE Backyard Mechanic marvis's Avatar
    Aug 2008
    I run grex sandwich plate with thermostat, -10 lines and FC oil cooler.
    Thermostat win.
    Jul 2007
    I use an FD RX7 oil/air cooler mounted off my rear bumper. has its own inbuilt thermostat... easy peasy.
    EDIT;
    dont you get concerned about stones off the rear tyre hitting that?
    Jun 2011
    Hi guys,
    Thanks for all the replies. Using cloth to cover the cooler in a full flow kit sounds simple and yet effective. At least it is a fail safe system as thermostat sometimes will get stucked and the oil will never get its way to the cooler at the end. For a full flow system, what size of the braided hoses should I use? -AN8 or -AN10?
    Jul 2007
    Quote Originally Posted by love ke70 View Post
    Making a shroud for it.
    Quote Originally Posted by AE112R View Post
    Hi guys,
    Should go -10. I have -8 lines and am a bit worried that they may not flow enough.
    A)water to oil heat exchanger is fine for cooling the oil, IF you have enough cooling capacity in the water system.
    B) or you could run a thermostat with oil/air cooler only..
    C) or, you could run a full flow air/oil cooler, then through a water/oil heat exchanger, to warm up or cool down the oil before going back into engine.
    this is useful as the water temp is more easily controlled, but only needed if your water cooling does not have extra heat rejection capacity to use A). it should also heat the oil up faster.. it's not useful if you want to run your oil and water at significantly different temps.
    regarding the original article, perhaps the oil cooler was not positioned well, or he was not driving it hard enough for any major difference to occur.
  1. Feasibility Study MA70 cooked engine rebuild
    Last Post: 06-06-2008, 03:04 PM
  2. 3SGTE Stock Oil Cooler - Oil Thermostat?
    Last Post: 17-05-2008, 09:29 PM
  3. can an engine oil cooler be used for auto trans cooler
    By Mr DOHC in forum Tech and Conversions
    Last Post: 09-05-2006, 06:12 PM
