Ok so you will need a 5ME dizzy like this
and your 1GGZE one like this
you need pull the gear off your 1g unit and fit it too the 5Me unit, this is relitivley easy the 1g unit is 10mm shaft and the 5me is 11.5 and 12.5 where the 1g cog has to sit so all i do is cut the longer 5m shaft off shorter and drill out the 1g cog to 11.5 mm with a 12.5 mm step in the gear end to make it sit in the correct position. This Is the lazy way of doing it and leaves the end of the gear unsuported to do it correctly you should machine down the shaft that sticks out past the new gear down to 10mm to suport the gear from both ends. I havent done this in the past and havent had an issue so far but I recomend you do it for longevaty.
Photo of 5me unit with 1g drive cog on it and a little dodgie machining with a flap dist to make it clear a step in the 1GGZE head, dont forget it should have a 10mm shaft poking out of the end of the gear about 10mm long to fit into the 1G head for support on both sides of the gear.
You need to pull the inductive sensors out of the 1G unit they look like this
Two are the once a rev sensors and the other is slightly different (its the constant pulse unit) they need to have the metal posts removed from them and modified to all be the same as the odd one.
So now you have 3 pickups that will match the 6 flags on the rotor all you need to do is mount them on the base plate inside the dizzy and make it all fit lol
more to come once i make a base plate ! Ps be carefull pulling the sensors apart there more delicate than they look , this one broke pullling the still post out of it. Luckly it was ok (tested witha mulit meter) and was just glued up with some Auto silicone, epoxy will do the same thing.
A dodgie base plate made up with tags from mounting plates out of the 1G unit. I used the vanes on the dizzys centre post as a guide to locate the sensors in the correct location, do try to get this right as 1 deg out on the dizzy is 2 deg out on the crank ! If your out by a little bit coke can can be used as shims to get it right.
Sensors mounted on base plate
Assembly of unit sensors fitted. Now all you need to do is remove 4 of the 6 tags from the Dizzy's post, ignore the post pictured in this photo its been setup for a hall effect sensor array.
Last but not least you need to find 3 igniter modules out of pritty much any single coil external igniter car . Usally there the ones with the coil mounted on the inner gard with the igniter under the coil. Wire the igniters to the sensor coils as you would a normal coil/distributor setup and then wire coil packs separatly to indevidual igniters.
