Page 38 of 85 FirstFirst ... 28363738394048 ... LastLast
Results 556 to 570 of 1266
Thread: 3T GTE Tech
  1. #556
    nuts Grease Monkey
    auckland
    Default Re: 3T GTE Tech
    Quote Originally Posted by toyo-al View Post
    I know I posted this before, but I'm urgently in need of the coolant bypass hose. They are discontinued from Toyota and I can't find them anywhere.
    Does anyone have a used one in usable condition or know where to get a new one from?
    Al
    have you thought about adapting a 2tgeu outlet or modifying the 3tgte one so that the hose only requires one bend? the 3tgte version is different to clear the sensors. but if you have brazing skills, it shouldn't be hard to hack off the 90' bend (steel outlet) and weld a different piece in there.
    Considering the age of those pipes, good luck finding one that hasn't already ballooned
    -Mark
    E2 + E7 fan
  2. #557
    Jul 2009
    anyone have a stocko oil cooler for the 3TGTE? mine has died
    my old ride:
  3. #558
    Apr 2010
    I Just noticed an oil cooler in the classifieds section $50 plus post
  4. #559
    Jul 2009
    its all good, ended up getting a new one made.
    my old ride:
  5. #560
    Apr 2010
    Speaking of oil coolers can anyone tell me if there is a thermostat in the factory cooler system?
  6. #561
    Junior Member Domestic Engineer TA22 GT's Avatar
    Quote Originally Posted by schnickles View Post
    Yep, the factory unit has a thermostat. Its inside the backing plate that sits behind the oil filter. From memory it opens when the oil temp gets above about 80C.
    This is only on the later model 3T GTE's as the early ones didn't have oil cooled turbos.
    Simon
  7. #562
    Apr 2010
    Cool thanks for the reply Simon i was looking into running a rx7 cooler on mine but it also has a thermostat built into the end tank...
  8. #563
    Quote Originally Posted by 3jcelica View Post
    Radar,
    Just go for wasted spark, use something like 2 x hyundai coil packs and mitisbishi j121 ignitors. Cheap easy and you have the CAS to fire it already.
    Hey all
    just a quick one about coild packs and igniters. I'm running adaptronic E420c with forged internals and a GT28r with about 18psi. I'm not to sure about ignition systems. Would what 3jcelica suggested work with my application?
    TA63 Celica Coupe (3TGTE) - Build in progress
  9. #564
    I believe that it will, except you will need to use 4 x hyundai dual output coil packs, not 2 as outlined by 3jcelica (remember yours has 8 spark plugs).
  10. #565
    Diz44zy,
    Works for mine, forged internals, 20psi gt28rs.
    You will need 2 wasted spark packs and 4 ignitors (if you wish to run all plugs, many people don't with no adverse effects)
    or 1 wasted spark pack and 2 ignitiors if runing 1 set of plugs
    (the hydundai packs come with 2x dual post coils)
    Some type of crank angle sensor (there are wheels which can bolt striaght on from www.diyautotune.com)
    the mitsibishi ignitors j121 can be found on vr/vs magnas and TE V6 magnas, heaps of these at the yards
    Roger
  11. #566
    Roger,
    I don't follow. Are you saying that you're running 8 plugs with only 2 coils?
    When running the 3TGTE head on mine, we used 4 dual output coils and 2 x M&W dual ignitors.
  12. #567
    Thanks Jas
    Phil mentioned he had called you a couple times already and that you have been a huge help. Thanks for that.
  13. #568
    No worries Josh
  14. #569
    Sorry should clarrify I run 4 x dual post coils and 4 single channel ignitors basically the same as yours.
    When you get them of the hyundai they come joined i.e 1 coil pack = 2 x dual post coils
    Roger
  15. #570
    Roger that Roger.
  1. 3T Versus 3T GTE conrods
    Last Post: 01-06-2007, 12:59 PM
  4. html in the tech section
    Last Post: 28-12-2005, 10:49 PM
