Hi there,
I would imagine that if the speedo is reading off the nissan box right now and you are running a 3.9 diff it should be 'reasonably' close. There are I believe adjustable inline do-hikeys for speedo correction, someone correct ME if I am wrong there!
You could possibly check it (if not currently registered and driveable so as to compare with a known late model car) by using jack stands under the rear axel and dialing up a given rpm in 4th gear and check the speedo reading i.e. with original gearing and tire size 100kph might have been around 3500rpm? (Better check my math here as I don't have the moroso power/speed calculator in front of me right now...) Now if 3500rpm/100kph tire speed on jack stands doesn't sound fun then use less rpm!
Jason
				 SR20 5 speed box to 1977 celica speedo, HELP
 but thats not the point right now.Also, what would be the best replacement to use and where do I get it from? Hey, be reasonable with the prices as its a tight budget.
			 Re: SR20 5 speed box to 1977 celica speedo, HELP
				 with the aftermarket tacho I have atm. So carnt tell what rev's im doing.
