I don't know if the cressida sensor will work with the w5x, but being an auto sensor my money would be on no rather than yes. But definitely don't need cable speedo, i have w58 in mine with JZX81 dash. Don't know what sensor was used though sorry
as title states will it work?
im half way through my manual conversion and am abit dumbfounded as to go about this speeedo issue (some of you may not be calling it a issue) wpuld the cressida sensor just work with the manual or do i have to convert to a cable speedo?
thanks luke
Why not swap with this fellow if you have the cable stuff:
http://www.toymods.org.au/forums/showthread.php?t=60454
In sydney as well
Chances are the MX83 speedo sensor will just screw on to the speedo gear housing, which is exactly how the speedo cable would have connected to the W58.
If it doesn't (ie, its a bolt on sensor), then you'll need to get a screw on one.
ok guys thanks for the input well it all plugged up without a hassle i'll drive it this weekend and fill you all in
thanks again
luke
