Results 1 to 6 of 6
Thread: Retrofitting your A/C from R12 to R134a gas.
    Negative Reputation Domestic Engineer Howieau's Avatar
    Default Retrofitting your A/C from R12 to R134a gas.
    Hey all,
    I came across this great article that the EPA released to A/C tradesmen for retrofitting A/C systems in cars from the old R12 gas to the new R134a gas. Invaluable read for anyone thinking of doing this. Will save you alot of $.
    http://www.epa.gov/ozone/title6/609/.../retrguid.html
    "There is a better way to do it, find it" -Thomas Edison
    Nov 2007
    Default Re: Retrofitting your A/C from R12 to R134a gas.
    Good information. Few of my comments
    Also Synthetic A/C Oil is avaliable, such as ERG500/1000 or SRO500, which are non hygroscopic.
    Always get the system flushed as Mineral oil is not compatible with PAG and R134a gas. You might be able to mix Synthetic ERG1000 with Mineral but that does not mean go ahead and do it, get the system flushed it's better not to mix oils.
    Always replace the Receiver/drier
    Essential Requirements to make an R12 System R134a Compatible :
    - System Evacuation to remove old gas
    - System Flush to clean old oil out - Metering devices such as Expansion valves cannot be flushed through, so the evaporator has to be removed so the Expansion valve can be removed in order to properly flush the evaporator
    - Receiver/Drier with X7 Dessicant - All new Reciever/driers are this type.
    - Compatible Oil Type - PAG or you can use a Synthetic Type like SRO500, ERG1000
    R134a Service valves are not required for compatibility, it will work without them. The reason why they were made a requirement is to try stop efforts of other gasses being put in, since gassing equipment that does not have R134a adapters will not fit on the valves.
    Optional Things you can do
    - Replace all O-Rings with HNBR Type, they are more resistant to leakage and warping than older NBR types. You can buy them from Ashdown Ingram. Sometimes I wonder if I pay more for the Single O-ring that they place in a massive plastic bag, or the massive plastic bag itself... But for most common sizes you can buy them in packs of 20. Old NBR O-rings work fine with R134a, but somewhat to a less extent that is probably not noticable, they may swell more but this does not mean they will degrade to buggery in minutes. If you have the time to go around the whole system (or most places reachable), they are not too hard to replace. If you are not confident doing this you will most likely bend and twist hoses while undoing them, then cry, then get a shop to do this for you. Since your o-rings might be very old and are likely to leak in the future or already have leaks, It's a good idea to just replace them to avoid any future leaks.
    - Replace Hoses with Barrier Types that have a lower leakage rate. Good idea anyway if you have a 20+ Year old car.
    What not to do
    Pressure Testing - Controversial issue as pressure tests use upto 300 PSI on the whole system, you're very likely to create a leak in the Evaporator, that usually never see's pressures as high as that. Most gasses have a U/V die, so it's easy to spot leaks with a UV light. It takes a bit of skill to be able to spot leaks with a UV light but I was able to find all my 7 leaks in my Soarer and fix them.
    Do not Mix oils that are not compatible.... If you don't know what's compatible and not, do not mix oils at all.
    Do not Mix gasses e.g topping up an R12 System that is low on charge with R134a.
    Do not try to be a genius and use gasses such as ones used in Air Conditioners (R-22), their operating pressures and characteristics are not suited for use in cars.
    Do not be a Hero and re-use your Receiver/drier. Apart from Compatibility of your old one with the new gas there are other reasons. The old one is most likely depleted and will not be able to absorb any more moisture, could be a possibility that the moisture inside of it will now circulate your system again. Old receiver/driers have a tendency to split their bags open and circulate the tiny desiccant balls around your system, they will clog you're expansion valve. If you have one that has inlets coming from the side you can most likely replace it with a universal ones for $8. If you have one that has pipes that bend downward and connect to the top of it, you will have to buy a specific one for about $40.
    Quote Originally Posted by Howieau View Post
    How can it save you a lot of money, its like $30 for the conversion?
    Tallahassee, FL USofA
    Quote Originally Posted by CrUZida View Post
    It recommends skipping a lot of the old BS, like flushing and hose & O-ring replacement for anything other then normal age/wear&tear, not incompatibility.
    Feb 2009
    In terms of cost, retrofitting is generally the cheapest thing when it comes to getting a system back up and running.Its more of the replacing leaking hoses/compressor etc that cost the most.
    Any system thats on R12 is nearly 20 years old,wear and tear are the main cost.A system MUST NOT leak before its regassed,that's the law these days.Smashing some dye in and sending it on its way is no longer allowed and any one doing it is not doing you any favours either.
    Nov 2007
    Cruzida Pretty much that is the price in Parts only, Reciever/drier $8, Oil $5. Charge Ports $15.
    Matty12 Correct, but it's allowable if your using gasses such as Hydrocarbons that is fine to let them off to the atmosphere. At $50 I get my system Evacuated and Regassed, so I can have ice cool A/C and detect leaks on the side when i feel like it.
    Allencr you need to flush a System before gassing with R134A, the existing mineral oil in the System is not compatible with R134a.
    Having a retrofit done the correct way though, Evac, Flush, New Reciever Installed, New oil will cost you anywhere from $300 upwards, as the biggest part in it is labour in removing the Evaporator in order to flush through it.
    If you want to do it the cheap crude way, just put some Hydrocarbons in and Happy Days.
  1. Jzx81 Aircon r134a or r12?
    By Jzxbenno in forum Tech and Conversions
    Last Post: 10-07-2012, 05:42 PM
  2. R12 A/C regassing
    By davedave in forum Tech and Conversions
    Last Post: 31-01-2009, 01:08 AM
  3. Retrofitting A/C
    By Rex_Kelway in forum Tech and Conversions
    Last Post: 08-01-2006, 12:01 PM
