Ther radiator repair shop recommended me to buy a new car~!
Looks like I will be going after market radiator and thermo fans.
Does anyone know how or please instruct me on how to wire the fan thanks.
My car was leaking coolant from the top end tank of the radiator.
It is 1jz with hydro clutch fan setup from a jzx81.
I brang it to radiator repair shop, they are searching where to source the top end tank for me and will give me a call back.
So far haven't heard back from them.
My question is, does the top end tank radiator of a jza70 with hydro fan interchangeable?
or is there any interchangeable top end tank for a jzx81?
In any case if the repair shop couldn't find a replacement due to it being jzx81!
what other solutions I have? I dont want swap for a non hydro fan water pump yet because it is a big job and I will leave that when my timing belt is due.
I have a plan B in mind, that is to buy a mx83 radiator and wire twin thermo fans, I have seen other people with ford AU fans installed with little mods, how am I going about the wiring?
thanks all,
Plan B also involves installing a non-hydro fan water pump (if done properly) so you might want to rethink that.
If you are going aftermarket radiator then why not get one made to fit the hydro fan?
I was running a JXZ90 radiator in my mx83/1jzgte with hydro fan and all working well until the tank broke and no radiator shop could find a replacement tank..
So I ended up ditching it for thermos just as that was the cheapest option at the time.
But would like to try and find a source of jzx90 radiators...
Did you removed the water pump completely?
and would you be able to instruct me on the wiring the fans?
jzx90 radiator
http://cgi.ebay.com.au/ALUMINUM-RADI...item20ade72aae
From looking at it, ooks like alot of work to make it fit a cressida?
thanks
Cant you just replace the top tank with a mx83 unit and run an aftermarket cooler for the fan fluid? Tried castle hill toyota for a spare from japan?
I have a mx83 radiator with ba falcoon thermos if you want it....
Radiators that have the INlet or OUtlet Halfway up the tank will normally block below that and collect shit ... Common with VL's .
11.72 @ 116.7mph = Quickest Stock Turbo Jzz30 series SoarerAnd 1st into the 11's
WOOOT!!!
Still going good![]()
http://www.youtube.com/watch?v=tc_7aRUGshw
PM sent officer!
I decided to go with mx83 radiator and thermo fans and recirculated the fluid. Seen a few on toyotacressida.net and they never have any problem so far.
thank you all for your inputs!
cheers,
i used a is 200 top tank & buypased the fan cooler & put a small trans cooler on the fan
