Results 1 to 3 of 3
Thread: tech help with standard 2t fuel system
    Nov 2009
    queensland
    Default tech help with standard 2t fuel system
    hey there i need some help with the fuel set up from the lines in the engine bay to the mechanical fuel pump to the carby and not to sure where the return line goes if anyone can help will be muchly appreciated cheers chris also if you can show me a pic of the engine bay which shows it thanks
    Melbourne, Victoria
    Default Re: tech help with standard 2t fuel system
    The only help I can suggest is to use correct punctuation and grammar and people will flock to answer your post.
    - Jackie Stewart
    Melbourne, Victoria
    There will be 2 steel pipes along the side of the engine bay (drivers side). The one closest to the front of the car is the outlet from the fuel tank. This will then go into the fuel filter and from there into the fuel pump on the connection closest to the bulkhead. Outlet is the other side (towards front of car - should have an arrow on it pointing out). This then goes to the underside union of the carb (I have a 32/36 Weber on mine). The topside pipe is for the return line that now goes back to rear pipe on the side of the engine bay.
    - Jackie Stewart
  1. Hi Tech Titles - Saturday 13th Febuary 2010
    Last Post: 09-02-2010, 09:11 PM
  2. 1ggte fuel system mods
    By MOOKIE in forum Tech and Conversions
    Last Post: 03-01-2006, 12:15 AM
  3. Replies: 1
    Last Post: 13-12-2005, 03:42 PM
