Have you checked the voltage from the alternator when under load? Eg Get someone to help you and check the voltage with a multimeter while your driving. Check it by contecting to any power supply wire inside your car....
Should be around 14 volts. If its low then at least you know if its related to the alternator..
Simon
so I'm pretty happy about that... (it means the battery voltage sensing wire is in the right socket now which is the critical part)
