Thanks for passing along the credit
Almost any N channel mosfet should work, just make sure it can take the current of the relay coil I only used the one written on the circuit as that is what I had, and it also fitted on the little veroboard circuit that I made to go inside my COR.
2N7000 from jaycar should be easy to get, and should work fine as a glance.
http://www.jaycar.com.au/productView...T&SUBCATID=475
Yeah the Zener diode is 16V, it's there to protect the Mosfet gate from any zaps / alternator overvolts etc.
Circuit goes 1k series resistor, two 470n caps in parallel to gnd, 1meg resistor to gnd, 16V zener diode to gnd, mosfet gate
Also don't forget that you need to connect the DI pin to +B or ignition to get the FPC pin to pulse!
Hope it works for you.
