Page 1 of 3 123 LastLast
Results 1 to 15 of 43
Thread: Lower Control Arms: the Length Database
    Default Lower Control Arms: the Length Database
    Ok, I thought this information might be useful to have all in one place.
    So basically the measurement which is useful would be the middle bush to the middle of the balljoint, giving the effective length of the lower control arm.
    So to start off:
    Control Arms
    Code:
    Model - Length - CT Dia
    RA40 - 300mm - 12mm
    TA22 - 300mm - 12mm
    AE86 - 300mm - 12mm
    KE7x - 300mm - 12mm
    XT130 - 310mm - 12mm (RT132 too?)
    MX73 - 304mm -12mm
    MX62 - 365mm - 12mm
    GE Sigma - 330mm - 12mm
    S13 - 350mm - 14mm
    Balljoints
    Code:
    S13
    bottom of taper diameter : 17.96
    top of taper diameter : 16.08
    height of taper : 14.72
    ratio : 1:7.83
    MX62 - BJ314
    bottom of taper diameter : 17.92
    top of taper diameter : 15.85
    height of taper : 16.71
    ratio : 1:8.02
    AE86,KE70,TA22,RA40,XT130 - BJ145
    LCA Inner Bushes
    Most old RWD Toyota LCAs use the same inner bush. The Pedders part number for it is 5830, and hence the crush tubes are all the same for these and all are interchangable on the inner end.
    These include: AE86, TA22, MX32, MX62, MX73 (NOT MX83), and i would assume most of the Corolla and Celica range.The Pedders online cattledog is a good reference for this:
    http://catalogue.pedders.com.au/parts.php
    I will continue adding to these as more information comes in, for now others should add their own too.
    If people can do it too, this picture by Hen is highly useful for measuring other bits, so if you want to fill that in too:
    Toymods Club Member #274 Backyard Mechanic Rallystanza's Avatar
    Default Re: Lower Control Arms: the Length Database
    Good idea for the thread Chris.
    Bloody Hen draws some nice pics and gets all the credit:-(
    Thought the main purpose for wanting to know the dimensions would be so you can interchange. When Interchanging arms you need to know a few more things such as the Balljoint taper (or even balljoint interchangability) and crush tube dimensions... Yes? No? Maybe?
    Jez
    R.I.P Peter Brock.
    Ah very true, ill add those details that i know to my post.
    Credit does go to you as well Jez.
    I think Hen has got some measurements for the MX62 and S13 BJ's.
    +Rep to j00.
    R.I.P Peter Brock.
    south australia
    XT130 control arms also use the same inner bush as AE86 TA22 and the like.
    There is an aftermarket part number for the XT 130 ball joints: BJ145
    The nolathane part number for the inner bush is 45087
    This is ae86 arm compared to Gh sigma arm
    (cheers to ae86dc for the pic)
    Do you have the length of the GH arm?
    south australia
    well they give an extra 60mm track overall if that helps. i dont have a measurement at the moment.
    Hm, so maybe 335mm is more on the mark. Ill keep it as an approximate in the original post for now.
    Junior Member Backyard Mechanic jonra23's Avatar
    Jun 2006
    Measured my GE LCA at 330mm, it doesnt have a crush tube in it, it has tapered bushes that pivot on a bolt in pin that measures 18mm.
    Ball joint press in section measures 40.2mm with fine splines line a wheel stud on it.
    regards
    jon
    Victoria, Mt Macedon
    The measurements I can give are:
    All measurements are from the centre of crush tube. The measurement to the balljoint is horizontally along the length of the arm (somewhat tricky to get exact).
    Car - Length - Swaybar - Castor rod - CT ID - CT OD - CT Length - Balljoint
    AE86 - - - -- 300 - 190 - 225 - - - - 12.4 - 16.5 - 59.5 - BJ145
    RA60 - - - -- 300 - 180 - 225 - - - - 12.4 - 16.5 - 59.5 - BJ145
    MX62 - - - -- 360 - 230 - 270 - - - - 12.4 - 16.5 - 59.5 - BJ314
    GE Sigma - 330 - 220 - 250 - - - - 12.3 - 17.8 - 64.5 - BJ122
    S13 - - - - -- 350 - 190 - 210/235 - 14.0 - 19.5 - 60.0 - BJ???
    Note the castor rod mount holes in the S13 arm are angled.
    BJ314 very closely matches the S13 balljoint.
    Hen
    Cheers Hen, some rep coming your way.
    I heard a rumor that XT130 is 310mm .. Can anyone confirm?
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    I cannot confirm Joel but I Have heard 315mm and given that they are an upgrade for AE86 in terms of track, i would also say that the BJ and Crush tubes are the same or similar enough for the sprinterboys to bolt 'em in.
    R.I.P Peter Brock.
    Junior Member Backyard Mechanic Dimitri's Avatar
    you must also remember that even if the taper is the same, the height at which the steering knuckle sits in relation to the ball joint pivot point is also important.
    i mention this as when using sigma lcas in an ae86 (/other toyota) the height of the steering knuckle is raised in relation to the steering arm. this creates more bump steering as it puts your rack end/tie rod end out of alignment in relation to your lca. (because the pivot point of you tie rod end has not been altered).
    Dimitri, you're right on how the AE86 steering arm sits on the Sigma balljoint, but this is because the two tapers aren't the same. I suspect that reaming the AE86 arm to the Sigma taper would fix this problem and make things a little stronger and more reliable.
    Yes XT130s use a BJ145 so they are a perfect fit for AE86 steering arms.
    Roughly small-mid old RWD Toyotas = BJ145
    Mid-large RWD Toyotas = BJ314
    You can cross reference balljoints with the PAJA catalogue pdf. Originally pointed out by Old Corollas.
    Hen
  1. Celica adjustable upper control arms
    By hypo23 in forum Tech and Conversions
    Last Post: 17-04-2006, 04:52 PM
  2. Help! Tell me what these control arms are out of?
    By 1973_KE20 in forum Tech and Conversions
    Last Post: 21-12-2005, 09:29 PM
