ok - i think i solved it!!!
30mm long cranks on 10mm dia shafts
shaft separation of 77.5mm
connecting linkage length of 55.1mm
LINEAR 1:1 ratio of angular movement in the range from 14deg to 76deg +- 0.6deg !!!
'wow' i hear you all say!!
but, yes, it is only a 62deg range of motion, not a full 90deg, but i think i can over come this by changing the ratios of the crank lengths at the throttle bodies (turning 62deg of main shaft rotation into 90deg of throttle body shaft rotation). i can probably tweak a bit more out of the 62deg, but it wont be much...
either way, its solved! - no crazy discs or bellcranks or gears. no slop. nice and simple
