So when you say Gizmo, you mean thats some type of manual bleed valve yes?Originally Posted by JustCallMeFrank
I think this is just a case of the little opening in a manual bleed valve just wasnt big enough to let all the air out quick enough to stop it getting to the actuator. Eboost must have a bigger opening in its solenoid that the manual valve.
Yes if you had a bigger spring it would be less sensitve and the problem could also have been solved this way too.![]()
Not that I really mind the extra info that's coming out of this...
