first up. that other item that you removed looks like a heater tap, to let coolant into the heater core. how are you going to block it up from the block to stop the coolant from flowing out?
i would connect it back up, its there for a reason.
does the engine crank over when the spark plugs are removed? if it spins over quickly then the engine isnt seized. you need to make sure there is fuel pressure there, try pulling of a fuel line on the rail and see if fuel shoots off when the ignition is tured on. if there is none then the fuel pump is dead or there is a major blockage.
these are some things to check when starting up an engine after it hasnt been started for a while.
i have a ms123 wiht a 5me. i start it every few months. it starts first go with a good battery, although it blows a fair bit of smoke (the enigne is gone)
