Guys,
The front turbo (I would call that turbo No.1) has a wastegate. This provides pressure control irrespective where the pressure is coming from. Note that this wastegate is puny and in many cases does not provide enough flow to adequately control pressure with a decent exhaust.
The rear turbo (turbo No. 2) has a "bypass valve". This bypass valve bypasses the main exhaust valve on the second turbo allowing the second turbo to start spinning up before the main exhaust valve and intake valves open. The mechanism is identical to the front turbo's wastegate, but the port is bored differently - it's on the turbine outlet instead of the inlet. It is possible to weld up the factory port and open up a port to the turbine inlet to function as a wastegate.
You would at least have to disable the two solenoids to stop the valves from opening. You may also need to disable the third solenoid that controls the bypass valve - I can't remember how that one is hooked up so not sure what would need to be done (and it's cold outside now so perhaps tomorrow).
As Norbie said - it's risky. You'll be feeding 3L's worth of exhaust into a tiny turbo and tiny wastegate... I would hypothesise with little doubt that it will overboost.
Can't you last even a little while without thrashing your car?
Mos.
