Originally Posted by
oldcorollas
i know
but those Hp calculators assume engines don't rev over about 6-7000rpm, above which the available time decreases..
so you have to "oversize" the injectors relative to the "proper" size... (is all i was trying to add)
This is where you have to be careful about the brand of injector you choose. Here is two different ends of the spectrum:
Rochester/Delphi = Big dirty dribbles and spurts of fuel. Typically chosen by the bigblock/blown V8 boys who need p00loads of fuel and dont give a shit about tuning resolution.
Sard = precise, accurate, and underrated flow figures (allowing room for high rpm/short pulsewidth applications without needing to oversize your injector). Has very good tuning resolution at the low end of the scale.
Here's a quick graph for the scientific types to understand
What does the graph mean?
well the graph shows that the Sard has much better tunability down at the low end of the scale. This means that your tuner can get your fueling much more accurate for all the times you arent burying your right foot into the go-pedal - which is 80-90% of your on street driving.
This means that your car will be much more economical to run with much cleaner emissions for your everyday driving.
Yes the Rochester has the flow everywhere else, but for the high tech performance engines we mostly run this isnt a problem - your tuner will just be running the injector at a higher duty cycle than with a Rochester style injector. At the high end of your RPM scale, tuning accuracy isnt important because the time between events is much much smaller, and thus inaccuracies have negligable effect on economy and emissions.
