Results 1 to 15 of 16
Thread: 20V Conversion, need to find a flywheel HELP!
    AB
    Default 20V Conversion, need to find a flywheel HELP!
    Working away on my 3a -> 4a 20valve conversion and was at the point this morning where i was ready to test fit the engine and see what needed to be moved/removed from the firewall and suddenly realized that the standad flywheel/clutch&plate are TOO BIG. some quick measurements and i found this...... std 4a flywheel is 267mm in diameter, std 3a flywheel is only 250mm in diameter. Now one could expect to just swap them but alas, 8 bolt pattern on 4a and only 6 bolt pattern on 3a. So my inquiry is thus. is there an 8 bolt pattern flywheel that is only 250mm in diameter that will work with the 4a? and if not how much risk am i taking by drilling out the old 3a flywheel to fit the 8 bolt pattern, i am thinking that i can get all the current holes welded in so that i am basically starting with a blank 250mm flywheel. i would rather have something that exists to work than to start modifying. please let me know if there are any ideas. and before the suggestion is made i will tell you that changing the bellhousing or the transmission is NOT an option (its FWD but the engine is mounted as a RWD would be)
    thanks in advance
    Default Re: 20V Conversion, need to find a flywheel HELP!
    Why do you not want to change the bellhousing? A 4A RWD bellhousing should work well.
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    The bigport/bluetops ran smaller flywheels than the later redtop/smallport 4age's. Unsure of sizes sorry.
    - LeeRoy
    Perth WA
    4AC have 6 bolt flywheels, unsure of size though, check for yourself, it may be the missing link you need for your project? For your reference, the 4AC RWD flywheel utilises a 200mm clutch - check to see if your 3A uses the same size?!? The 20V motor uses a 212mm clutch, so naturally has a larger flywheel friction surface, however the overall flywheel size is the same. I'd be reticent to redrill your flywheel, especially considering you are installing a motor that likes to rev.
    Interesting project, though you're not the first - I've seen a 20V motor in FWD corolla with that kinky North South engine orientation, I've seen one here in Perth (I have no idea where your location of AB is?!?).
    AB
    Quote Originally Posted by TurboRA28
    the differential is ahead of the bellhousing.
    AB
    quickly measured the clutch disk at 190mm. still hoping to find something that will work.
    Fava beans and chianti Backyard Mechanic AE86slut's Avatar
    New South Wales
    Quote Originally Posted by DeftAnesthetik
    BWAHAHAHA!!!11
    Sorry... It just looked amazingly like some poor, deformed child on that medical miracles show or whatever it's called... Like it's foot grew out of it's head or something.
    Anyway, the only helpful thing I can offer here is to advise you not to go welding and re-drilling your flywheel.
    I am not a doctor, or a mechanic...
    A.K.A Otomoto
    All new - Fart!
    Quote Originally Posted by Vios-GT_07
    it was 10,000 kms b4 it saw the red-line.. but even then i seldom push it that hard unless i have to prove a point i.e. competition
    south australia
    what car is this going in? and whats that setup out of?
    vic
    Its a turtal G/ box (sorry tercel) they are a strange bit of gear , id be a little worried about a 20 V with this G/ box .
    The input gear is not known for its brute strength and thats behind a 3A
    Dave
    S.A
    what about a 4afe flywheel just a suggestion i have no idea of there size but they are part of the 4a family
    i have thought a bout tercel running gear behind a light weight 4age all wheel drive hill climb cart ! would be an AWESOME piece of gear i recon !!!!
    AB
    looking around and found that 3e and 5e can come with proper size clutch, does anyone know the size and bolt pattern for these flywheels?
    if you are after revs and such, now seems like a good opportunity to get an alloy flywheel made up to your needed specs
    AB
    yup, investigating prices already.but still keeping my fingers crossed for something thats easier to replace if need be.
    Junior Member Grease Monkey progkamol's Avatar
    A Fidanza or Ferdanza (not sure the name, if I see then i'll know) would do the job. Its a light weight fly wheel. However it is not that light until you will lose 70% of your torque ...
    thanks in advance
    HOW THE FARK DOES THAT WORK??????///
    what car is all this going into?
  1. MA70 --> JZA70 Conversion
  2. (TA22) 2T - 2TGEU conversion (now with pics)
    Last Post: 13-11-2006, 09:52 AM
  3. Sam's MA61 7MGTE Conversion
    Last Post: 10-11-2006, 12:08 AM
  4. KE20 Front drum to disc conversion guide
    By BSIDE in forum Tech and Conversions
    Last Post: 24-03-2006, 04:00 AM
