Results 1 to 10 of 10
Thread: Steel tapers
    Default Steel tapers
    G'day
    Im looking for somewere to get steel (tube) tapers with specific IDs/ODs,
    wheres the best place to go? engineering company or steel supplyer,
    or should i get some tube and weld and grind it? or even machine up the inner taper heat some steel tube and slam the inner down the middle to strech it
    Rohan
    Default Re: Steel tapers
    for bodging up steering arm holes??
    lol nah, its for some in car electornics mountings (for a live video feed in a rally car for when the company bosses come out)
    if the sizes are big/short enough, why not just get them lathed??
    what sizes are you after?
    Thin wall tube probly wont do you much good if you want serious taper. You may to have to get it machined out of solid bar.
    yeah i might just lathe something up the problem is its 50mm at the thick side, dont know if our lathes go that big (we have small lathes), so getting them done by a machineshop is the way to go?
    also it needs to be tube and ID needs to be smooth and follow the taper
    now 18rg powered... Grease Monkey 18rc turbo's Avatar
    Jun 2006
    getting the taper on a lathe would be easy, its only a tool change to do the I.D. as well as the O.D., what length are you looking at???, and what angle for the taper???
    3 x RA23's + 2 x RA28's = No Backyard!!
    18r-g + straight lpg + t25 turbo + 14 psi = FUN!
    The latest Toy : http://www.toymods.net/forums/showthread.php?p=807137
    they are about 90mm long with a drop of about 10mm so a fairly gently taper
    a machinist could wip those up in a few minutes really.
    i was gonna say.. 500mm chunk of steel in rally car could be dangerous
    only issue is if the ID is large enough to fit a tool into it.... as long as it is, it should be no issue for machinist to whip up in a few minutes
  1. W5X Speedo Drive Comparision (Steel plate vs Alloy plate)
    Last Post: 12-08-2011, 07:58 PM
