Results 1 to 10 of 10
Thread: vacum sensor part number
    Junior Member Grease Monkey bassy's Avatar
    Default vacum sensor part number
    hey im after part numbers for vacum sensors. after one for my 4agze, trying to find out if any other engines use the same part.
    89420-16050
    100798-3130
    is the part number of a 4ef out a starlet.
    can someone please check there 4agze?
    thanks, bassy
    VZ engine series FTW! Grease Monkey Timma's Avatar
    May 2006
    Default Re: vacum sensor part number
    that second one might be the same for the 2vzfe (100798-3130) will confirm soon
    vzv21 camry 2vzfe v6 - aka mr burble or white one
    bump. anyone got a map sensor
    89420-16050
    EP9#
    EL5#
    EL52
    for some reason my epc didnt even bring up 4agze lol
    and the second p/n it didnt even recognise...
    i could look thru the 4agze section but it doesnt have titles...so its too much of a PITA, ring toyota and ask them
    EP9#
    EL5#
    EL52
    what are these numbers? and what is an epc? yeah im gonna ring round tomorrow. thanks love ke70
    sorry, epc = electronic parts catalogue
    those numbers are models the part was used in, it wouldnt tell me engines, but its easy enough to google a model and see what engine it has.
    its an E series motor of sort obviously
    ST185 GrpA #135 Automotive Encyclopaedia Toobs's Avatar
    Quote Originally Posted by bassy
    EP9#
    EL5#
    EL52
    EP = Starlet
    Neither of those PN's come up in my ~1995 Euro EPC... stupid thing.
    i alredy have the part number for the stralet, im after part numbers of other engine particually the 4ag(z)e. all im after is a comparison to see if there is an alternative. thanks for the imput people.
    does no one out there have a map sensored 4agze?...
    theyre not the same part, when i typed in your part number thats all it brought up
    Forum Sponsor Grease Monkey
    If you want an alternative map sensor you don't need one with the same part number, just the same pressure/voltage relationship.
    As far as I know they are all linear so with a voltmeter and a pressure source (like a FI car with a boost gauge) you can find the output characterist and match it with another one.
    Like 1JZ's reach 5 volts at close to 15psi ST185 is a bit higher around 18psi or something and ST205 is around 26ish.
    http://gtfour.supras.org.nz/mapsensor.htm
    doesn't even need to be toyota to work
  1. AE86 Rear Discs Part Number
    Last Post: 12-03-2006, 04:09 PM
  2. 98 Corolla Model Number, AE10?
    Last Post: 24-02-2006, 03:45 PM
