Results 31 to 45 of 53
Thread: LPG conversion
    Default Re: LPG conversion
    Firstly, "Imperial Welch Plugs"? I assume you mean a welch plug you could purchase from a repco or somewhere?
    And what's stag?
    Facebook | LinkedIn
    With a dedicated injection system, LPG is a great option. I want to do some work in the future with this and see if the real world benifits live up to the theoretical ones.
    In my opinion:
    -LPG has a higher octane rating, which means you could theoretically run a forced induction high-comp motor and benifit from the responsiveness that comes with that.
    -If you inject the liquid close enough to the valves (preferably right behind the inlet valve) the vaporising cools the inlet air, effectively working as an intercooler. I cant quantify HOW much cooling this provides... i dont think it would replace an intercooler... but i'm interested to find out.
    -LPG also doesn't wash the oil of the cylinder bores as much as petrol does, this adds to longetivity of the engine.
    -LPG is cheaper
    -The concept that a litre of LPG wont get you anywhere as far as a litre of petrol comes from the non-optimised mixer days, where the engine had to run on both fuels. If you run a higher comp and/or forced induction engine optimised for LPG only (to suit the higher octane) you will get very close to, if not the same, litres/distance as a petrol setup
    Add to this the benifit of being able to control management maps like EFI engines and you will start to realise why i want to play around with near-direct LPG injection.
    Time will tell!
    Timbo
    Current rides...
    2) White RA25ST
    1) Red RA28LT (NOW WITH 1G )
    Sounds like a plan you have there boss..
    I have it upon very reliable info that there is an uprated type of converter that is far more responsive than the typical 'modified B2' converters...
    May be no need, other than the mapping option, to go for LPGFI
    Facebook | LinkedIn
    Hoppers Crossing
    strad. holden v8 welch plugs if memory serves
    stag is the red gooey shit you put on welch plugs before you tap em back in the block. stag jointing compound
    timbosaurus. not much cooling benefit from LPG if injected as a vapour matey. if injected as a liquid though, very different story...
    Montrose
    When plugging injector holes in the past, I've just used pieces of aluminium from the scrap metal place, chewed down to sized on the lathe and pressed in. I guess having a lathe helps;-)
    Quote Originally Posted by Grega
    That's what i was getting at mate
    i mustn't have made myself clear
    So you have any idea HOW much cooling it provides? Is it comparable to running meth?
    Timbo
    Current rides...
    2) White RA25ST
    Hoppers Crossing
    all good
    i don't to be honest. when my celica is sorted with the turbo i'll pop a thermocouple in my LPG low pressure supply hose and see what temp it is. would be good to know hey
    comparable to meth? no idea..
  8. #38
    are you injecting liquid or gas?
    Current rides...
    2) White RA25ST
  9. #39
    Hoppers Crossing
    neither. GRA
    i *may* look at vapour injection. see what shinny can get injectors for
  10. #40
    Gotcha... i'll keep looking towards liquid injection.
    Current rides...
    2) White RA25ST
  11. #41
    Out of curiosity, if one was to go dual fuel, then would it make more sense to run say 5% petrol in with the gas, mainly to keep the injectors lubricated? From my understanding the gas will easily increase the burn of the fuel too.
    Oh yeah, and while im on the topic i was looking at an interesting gas addon to diesel cars. Basically they use a smaller cylinder and only add in about 10% of the fuel to increase fuel atomisation and burn. Anyone else looked at that style? I reckon if i end up getting a Surf ill go down that option too.
  12. #42
    I've heard of the diesel/LPG before overseas, but never here.
    I'd be wanting someone experienced in that area before I let them loose on the Caldina engine.
    Though the thought of not getting the wooden spoon at a dyno day appeals
  13. #43
    Diesel/Lpg has been here for years in commercial applications. I used to run Diesel Generators on trains in the mid 1980's. That is LPG powered diesel lombardini Generators. Used to use 2 45 Kg bottles every 16 hours.
    Have also seen them used in stationary situations.
    Regards
    71 ta22 2tgeu,ke35 18rg, ke 35 3k auto,74 ta22 2tg,73 ta22 2t,80 ra40 18rgeu,92 kawasaki gtr1000,95 nj pajero, 2011 jeep patriot,2011 aricat jd495,1979 leyland motorhome (350chev),1995 Mitsubishi Delica
    Too many cars so little time
  14. #44
    That's still a little different to a small engined fwd import.
    Most people are worried by the fact it doesn't look like anything here, let alone be powered by an engine that isn't widespread here either.
    Besides, apart from a tank that sits in the spare wheel well, I don't want to loss any carrying space apart, I already carry a full size spare up in the back because the spare wheel well only fits a space saver.
  15. #45
    you may lose the dyno days, but on the flip side you could probably tow everyone home when they break down! :-)
    Facebook | LinkedIn
  1. MA61 - RA65 Struts & Powersteering Arms conversion
    Last Post: 04-06-2013, 10:38 PM
  2. MA70 --> JZA70 Conversion
  3. KE20 Front drum to disc conversion guide
    By BSIDE in forum Tech and Conversions
    Last Post: 24-03-2006, 04:00 AM
  4. AE86 Gearbox Conversion Options
    By Garth AE86 in forum Tech and Conversions
    Last Post: 20-03-2006, 02:30 AM
  5. ST162 Conversion
    By Pure-SX in forum Tech and Conversions
    Last Post: 30-01-2006, 02:34 PM
