of course you can
hello all
next big challenge is to find out if the crown can be converted to LPG.
89 crown, V8, same motor in soarer? lexus?
anyone got info please.
crown crazy:
PS. not an aprentice, just lead footed middle aged [lady]
of course you can
Where i work it'll cost you $2300 for an LPG conversion however we only do Fords but it gives you an idea.
taxi conversionist!
* shoots and runs *
any car can be converted to run lpg, its just that some motors require different hardware/modifications to run properly on it.
my 18rc for example isnt a fuel injected motor, so i just need a butterfly and a gas mixer (basically a gas injector/meter) in terms of hardware to make it run. I also fitted hardened valves (lpg doesnt lubricate my valves the way the old leaded petrol used to) and bronze valve guides to stop the valves sticking (also because of no lube).
Most EFI cars also require a control module to interface with the computer and assist in regulating the gas flow.
I am not familiar with a crown V8, but any reputable LPG conversion shop should be able to tell you over the phone exactly what is required to run LPG on your motor.
Are you intending on making it dual fuel??? Dedicated LPG???
hope this helps...![]()
3 x RA23's + 2 x RA28's = No Backyard!!![]()
18r-g + straight lpg + t25 turbo + 14 psi = FUN!
The latest Toy : http://www.toymods.net/forums/showthread.php?p=807137
dedicated LPG is much better and you can just get a LPG carby then
an engine designed for unleaded should have no worries running on LPG![]()
Originally Posted by love ke70
aye, i forgot to mention that... must have been that last can of VB...![]()
gee! thanks guys! i'm none the wiser, guess i just ring around lpg convert places....
the V8 is efi, same as in soarer? lexus?
i have a twin turbo supra engine on lpg carb
they just plug the injector holes if you go dedicated.
if you dont want a performance setup you could even look at lpg injection...its a growing world
any car can be converted to LPG I did an RA23 3 days ago, cost $88 for everything and took 6 hours to install. Just gotta go get it checked and complianced ($100 or so)
where the fuck did u get tank pipes and carby for 88 dollars?
i sense bullshit
Probably second hand stuff.
But even so is still way cheap at that price.
PM out mrshin ,He just converted a celsior(1uz) to straight gas with no probs,runs sweet.
He is the horses mouth.
cheers joe
Check ebay, there are some cheap tanks on there. Some are out of date and need restamping but still cheep..
I just gotta find some secondhand gear up here in Syd and the 4runner will be gas![]()
tanks if OK are $120 to get checked and re-tested. try and get an APA tank if you can as they seem to be the better ones.
my TA22 uses a commodore APA tank and commodore mounts shortened and modified to suit the TA22.
joel. what do you need? let me know i might be able to help![]()
