Results 1 to 14 of 14
Thread: ecu tuners in adelaide
    Default ecu tuners in adelaide
    anyone wanna reccomend somewhere not boostworx?
    will need to be spliced into the ecu harness (its only 8 wires+12v/gnd,its a piggyback, tuner will need to do one last double check to make sure the pinout is the same as the manual provided)
    manual and tune guide here: http://toyotanation.com/forum/t61019.html
    IF YOU THINK (edit KNOW) YOU CAN INSTALL THIS FOR ME (ill pay, and im in SA ppls hence asking for adelaide reccomendations) PM me, this will leave me only requiring a final dyno tune at a shop.
    air, fuel and timing adjustments, dyno preffered. laptop (or pc) REQUIRED the ecu's software will be provided. car IS NOT odbII.
    S.A
    Default Re: ecu tuners in adelaide
    what brand ECU???
    is certainly not a Automotive Encyclopaedia suss_slide's Avatar
    S.A.
    i know of a good mate whose dad does it, go to the corner of south road and daws road, there a big blue sign that says "1111" thats all, its on the corner there^^ ask for john. good guy and he knows his shit.
    Now targeting, people who are now targeting!!
    Low rep Grease Monkey
    S.A
    My brother used to work for RPM Performance Centre and is going to start up his own Performance Business called "Custom Automotive". If you would like to talk to him, his name is Darren Armitage and his number is 0410546004. My brother is a very fastidious worker. If its not done correctly, he wont do the job!! He is also doing custom AE86 build-ups and practically anything JDM or modified ADM.
    Give him a call, you wont be dissappointed!!
    Regards, Ben.
    Quote Originally Posted by terra
    Care to explain why?
    south australia
    Quote Originally Posted by suss_slide
    used to work at turbo tune but had a bit of a kerfuffle with the other owner (dave)?
    bosch authorised mechanic? next to some boat place i think?
    is that the store you are talking about?
    if so then yes i can reccommend that same John.
    Junior Member Backyard Mechanic gixer's Avatar
    Allan Engineering 85272266, they have engine dyno, most of top IPRA cars tuned by them.
    The only problem with Allan is that they ONLY have an engine dyno.
    Just remember that when you are planning things, i forgot that fact and was set back by a bit.
    HHeLiBeBCNOFNeNaMgAlSiPS Backyard Mechanic
    I know sean had some of the tuning done for the crown at Blackwood Dyno. The guy there Mike is pretty good and seems to err on the side of caution. Not too expensive either which is probably a consideration.
    I'd be interested to hear what you manage to get out of the 3vz.
    you know what I mean this electric stream
    and my tears in league with the
    wires and energy and my machine
    this is my beautiful dream
    Nice..... Grease Monkey Rex_Kelway's Avatar
    It might be worth giving Jaustech a ring on (08) 8266 7244. They do good work and when he wants to be Darren can be quite easy to get along with, aside from that he is a brilliant tuneriser.
    Jaustech or JazMac
    i used jazmac with the microtech tune on my soarer and the work was top notch
    Project Soarer II - Sold
    Evo 5 - The silver fruitbox
    JZA80 Convert Backyard Mechanic
    I'd be interested to know why not boostworx, a couple of friends of mine have had their cars tuned there and they have been quite happy with the results. PM if you don't want to put it up in public
    Olde ****** Automotive Encyclopaedia ToDa30/4's Avatar
    south australia
    Turbo Tune opp. castle plaza ,Mick Keen tunes my GT4 ,& John K. has also in the past with good results . dont think wiring it in would faze them.
    Project ST215W 300 AWKW Killerwagg'ss .staring in the garage .soon
    ST185R 385 AWKW now SOLD ..Daily '89 Eunos Roadster.
    Project '75 KE30 37.4 RwKw PIMPster. doing it for Angela RIP 1964 - 2011
    Quote Originally Posted by ma61turbo
    last time i was there i got laughed at by the guys running the dyno for the club psi dyno day ^^ (92.6fwkw with sensor issues, and my heavy wheels which alone account for ~0.5s 0-100)
    im one of those first impressions count people (a reason why i had my exhaust done at probably the most expensive place in adelaide, D&T)
    im currently finalising payment / waiting on delivery of the SMT6, i should fix a couple of engine mounts during this time ^^
  1. ECU error codes flashing through ABS light??
    By Alchemist in forum Tech and Conversions
    Last Post: 25-06-2006, 08:41 PM
  2. Replacing 7mgte ecu
    Last Post: 17-04-2006, 10:43 PM
  3. TVIS not engaging due to ECU?
    By phrostbyte in forum Tech and Conversions
    Last Post: 03-03-2006, 12:39 PM
  4. Can the ECU get a fault wrong?
    Last Post: 28-02-2006, 01:28 AM
  5. 1JZGTE ECU Part Numbers
    Last Post: 13-02-2006, 11:31 AM
