Results 1 to 5 of 5
Thread: R154 Bellhousings
    Wazzzzup!? 1st year Apprentice ToranaJudd's Avatar
    Default R154 Bellhousings
    How do i find out the difference between a 7mgte bellhousing and a 1jzgte bellhousing assuming a r154 gearbox is used?
    Is there distinct external features or just bolt pattern differences?
    Cheers, Judd.
    Who said turning corners was important?
    Its just the size of the wheel stand that counts!
    Default Re: R154 Bellhousings
    Also, Can i determine this by the R154 gearbox that came off the bellhousing?
    Stampings, marking etc etc?
    Cheers, Judd.
    Jun 2006
    Toyota has ahabit of casting numbers on things, have a good look all over bellhousing and you will probably/may find engine series cast on to bellhousing.
    Junior Member Backyard Mechanic manny's Avatar
    M series R154 bellhousing is 196mm long
    JZ series R154 bellhousing is 171mm long
    Both M and JZ series input shafts protrude 190mm from the bellhousing to gearbox mating surface
    So without a measuring tape and purely by the naked eye, if the input shaft protrudes past the bellhousing to engine mating surface it's from a JZ series engine and if it doesn't protrude, it's from a M series engine.
    Also looking from the front of the bellhousing, M series has starter in about the 1 o'clock position and JZ series in about the 2 o'clock position.
    GSE20 IS250 - daily
    UZZ30 Soarer - 1UZ-FE/R154/Adaptronic - trackday roughie
    UZZ32 Soarer - Active Hydropneumatic Suspension (A-SUS) & Active Four Wheel Steering (A-4WS) - cruiser
    R154 boxes from about 1995 onwards will have a remote shifter as well.
  1. r154 shifting experiences
    Last Post: 24-11-2009, 09:47 PM
  2. How much power can an r154 handle
    By 53TUP in forum Tech and Conversions
    Last Post: 18-10-2006, 11:19 AM
  3. Any one done R154 to 3sgte, or is there a bell housing available
    By Raceflo in forum Tech and Conversions
    Last Post: 16-05-2006, 02:38 PM
  4. R154 electronic speedo conversion...how to do?
    By Robbos_Toyotas in forum Tech and Conversions
    Last Post: 24-04-2006, 01:56 PM
