Josh, I'm guessing the spark plug gap is less than 0.7mm already?
I've never played with them, so I can't really say, but I've heard both praise and criticism for the coils used on LS1's. I gather they have the transistor built in, so need no separate igniter. You can try upping the voltage going to the coils, see if that helps. Josh, I'd be looking at the settings, if you can change them. Both the EB Falcon and the SR20 I told you about run a Microleb with Bosch coils, and both run past 30psi and make a reasonable amount of power;-)
yeah plugs are gapped down to .75mm
ill look into the dwell when i get it back on the road, computer needs a new map sensor anyway as 25psi just aint enough
Dwell can be adjusted on Microtech LTX ecu's, though I haven't messed around with them myself.
I'd reduce that gap a bit more.
From memory Norbie was having issues @ 18psi with 0.8mm
I think he dropped it to 0.6mm, but can't remember for sure.
yeah its all worth trying hey
sorry this got off topic alittle
thanks for your help, ill let you know how it goes
last OT![]()
you could try platinum/iridium plugs perhaps, given the smaller electrode and more chance of igniting mixture...
or perhaps send an email about plugs to NGKspark.com.au and see what they recommend.... in terms of both type and gap..
second last OT
have your tried using "colder" plugs?
im running iridiums and they are a heat range colder
so maybe![]()
shane as for coils i can say a certain 4age i know of runs LS1 coils to 9000rpm with wasted spark and no worries
LS1 Holden coils have a built in igniter unit into each one (as mentioned)
making them nice and clean to mount on the firewall too
a set of 4 trade was $70 if i recall?
also SR20 (bosch i think) coils/igniters are much the same but more $$
Last edited by Garth AE86; 19-12-2005 at 12:56 PM. Reason: didnt finish the sentence (oops)
Garth - 100% AE86 Addict
AE86 - Levin & Trueno - The Legends Live On!
'AE86' - Toyota Sprinter Trueno GTV
"It's not a street car if you can't drive it on the street. The car has to be safe and fast on any road condition" - Keiichi Tsuchiya
err, these LS1 holden coils wouldn't be made by Holden would they? They would be just some Bosch or similar?
Also what do they look like? You got a pic![]()
i dont think so
lemme check when i get home![]()
Great thanks.
How did you go about getting yours? Just walk into a wrecker and rip some of a car?
call holden spare parts
Wow, you really do like throwing money about!! Holden charge a mint for any of thier newish gear... even the VN/VP stuff is rediculous. The VP rear tail lights that go on the bootlid(the mini ones) are $240 new trade from holden... imagine what the coil packs are worth??Originally Posted by ae86drift
