yes you have to take the whole fuel rail off. do it in this order
1. clean your engine with degreaser then hose off and dry (or take steps to keep it all clean)
2. unlpug your fuel pump/ relay/fuse or whatever and turn the car over with the pump not running (this gets rid of the pressure in the system and you wont spray fuel all over the place)
3. loosen fuel rail bolts
4. twist injectors a bit to loosen them up
5. remove fuel rail, watching where all the O rings fall so you can find them
6. remove injectors, try not to drop dirt down the injector holes.
