Results 1 to 6 of 6
Thread: i need help please guys
    n.s.w
    Default i need help please guys
    i have a ae71 corolla and i want to put in a 4age and need some help i got a motor to start off with and here is what i have.
    4AGE Engine, Computer, Gearbox, Driveshaft, Radiator, Power Steering Pump and some other engine parts from a 1990 Toyota Corolla SX Seca (100KW).
    can u please tell me what else i need to get to get it up and running for rwd in my ae71
    thanks
    Default Re: i need help please guys
    Do a search on here for this conversion and also how to put a 4age into an AE86. Also try www.ae86drivingclub.com.au and twin cam forums. Between all 3 you should find everything you need to know.
    - LeeRoy
    is certainly not a Automotive Encyclopaedia suss_slide's Avatar
    S.A.
    well, ur gonna need all the RWD manifolds for it, then ur gonna need a new gearbox, thats all i know.
    Now targeting, people who are now targeting!!
    ST185 GrpA #135 Automotive Encyclopaedia Toobs's Avatar
    Been there done that...
    http://forums.toymods.org.au/index.p...art=0&count=60
    Most of the pictures still work.
    you need to cut and shut your inlet manifold ($80) as there is no RWD small port manifold available. then you need an exhaust manifold (around $250 for TRD copies?) then you need to modify your clutch cable, but youll see what you need to do when you get there as the extractors foul the line ($40). then you need to get an exhaust made up but everything else you can do with what you have easily.
    pm me for rwd extractors to suit
    as above done heaps... nearly too easy.
    Black Betty >HERE!<
    (\__/)
